hardware acceleration card
In one other topic(closed) Glenn recommended hardware acceleration card for Premiere. What is it? Never heard about it
thanks for any help |
Something like The Canopus products can run Premiere in real time.
For Premiere Pro, most people on this forum say the Matrox RTX100 is the top card you can get. I have never used one so I can't tell you much, other than it provides acceleration for specific effects and adds a few effects too.
There are other cards by companies like Canopus... they aren't as good for Premiere Pro, although they are also good for other associated programs (i.e. Edius). |
These cards will accelerate certain effects and offer near real-time working
with SD footage (don't think it works with HD yet). However, keep in mind that they usually tie you to a platform (Windows + Premiere) and seem to have short support spans (ie, not much [none?] of the older cards that supported Premiere 6.x work with Pro?). They usually offer analog in and out as well to support you with that. Whether you need or want to have one depends on budget and how much you are going to use it. Personally I work with Sony Vegas without any hardware acceleration and I have no need for it at this moment. |
Does hardware acceleration card affect while computer exporting on mini dv? I always had problems with dropped frames while exporting, would that fix it?
Hello, I use PPro 1.5 and have 3 setups. 1) PPro all by itself. It runs great and is usable without any additional accelerator cards. 2) PPro, with Matrox RTX100. Great Company, Darn Good RT transitions and effects, solid performance and great support. 3) Canopus DVStrom. Nothing but problems, great forum support - but poor company support, they only care about the buck and those that agree with them - everyone else is alienated. :-( Any time that you add something to your system, you are adding support issues as well as the added benefits that you are seeking. I use my RTX100, so I would say that it represents a value to me... and I would buy another one. I use PPro by itself and it is fine, but I use the RTX100 more often. I do not use the Canopus product in general. I use it occasionally to encode for DVD, but that's about it. |
<$30 firewire card firewire cable to deck or camcorder to NTSC monitors (I'd hook up both Svideo and composite/RCA connections) |
Steve: I simply use a DV camera or deck for analog in and out, that includes
out to a broadcast monitor or TV for monitoring purposes. The new Vegas 6 also includes an option to output to a secondary computer monitor in fullscreen. So I don't need an accelerator card to do analog in/out as long as I have a DV camera that supports that, a DV deck or a analog <-> DV converter like one of the Canopus ADVC line of devices. |
