MATCHING DVX with XL1s
Shooting a concert in 60i, will these two work ok together?
You can adjust the gamma curve on the DVX100 so it matches the XL1s more. Turn off the film-look stuff on the DVX100.
You could also shoot frame mode on the XL1s and 30p on the DVX100 if you like the 30p look, although the DVX100 will have more vertical resolution if you do that (about a third more). 2- At the shoot, try to get the same white balance and exposure levels between both cameras. Have a white card or something and shoot it so part of it zebras on both cameras. Having the same exposure level would be great since colors shift as they approach clipping and the soft shoulder/knees in the camera's gamma curve. If one camera does that then it will be hard to match the brightest colors. 3- You could also try matching up the saturation and edge sharpening between the two cameras within the camera's menus. Alternately, you might want to turn sharpening down on the DVX100 as much as possible as it should be slightly sharper than the XL1s. You can check things out with a resolution test chart at: http://www.bealecorner.com/trv900/re...x.html#EIA1956 I haven't seen footage from both cameras together but they should match up fairly well. What I've written above is what I'd do to match the cameras up. |
Glenn - Can't thank you enough - Have a great weekend
| All times are GMT -6. The time now is 02:55 AM. |
