-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   YUV 4:1:1, 4:2:2, 4:2:0 Question (https://www.dvinfo.net/forum/open-dv-discussion/38686-yuv-4-1-1-4-2-2-4-2-0-question.html)
Craig Bellaire February 1st, 2005 07:42 AM
OK I keep hearing about several different things here..DV is 4:1:1, I keep hearing that DVD MPG2 is 4:2:2 but also some say DVD Video is 4:2:0 and HDV is 4:2:0 Just wondered if DVD is really YUV 4:2:2..... and which others are YUV 4:2:0, YUV 4:2:2 and YUV 4:4:4 ..thanks
Graeme Nattress February 1st, 2005 08:43 AM
It's Y'CbCR for digital video. YUV is something that gets formed in the path to create composite and S-video from component analogue.
DV NTSC is 4:1:1
DV PAL is 4:2:0
MPEG2 DVD and HDV are 4:2:0 (but it's a slightly different 4:2:0 to that which PAL DV uses)
PAL DVCpro is 4:1:1
MPEG2 can be made to run at 4:2:2 for pro applications, but DVD and HDV are the 4:2:0 version.
Graeme
Craig Bellaire February 1st, 2005 09:07 AM
Perfect..
this is perfect... thanks so much
John McManimie February 1st, 2005 02:13 PM
Look here:
http://www.adamwilt.com/DV-FAQ-tech.html#colorSampling
