DV playback looks bad? Go High Quality!
Per default the two often used players (Windows Media Player
and QuickTime) on the Windows platform default to a low resolution presentation when playing back DV. Edit: it seems this "issue" exists also on the Mac platform, see the posts below! The problem is two-fold. When you play back QuickTime footage the file looks like full resolution but very poorly. With the Windows Media Player (WMP) it will only show 50% of the available resolution which reduces the picture size by half. So if you have been asking yourself why the footage looked so small or so bad in comparison to a TV you have just found ONE of the reasons. There are more reasons like color accuracy of a computer monitor versus a TV or production monitor. A TV (interlaced) also works differently than a computer monitor (progressive). Just check the following QuickTime player screenshots on my Windows XP Professional computer to see for yourself:(files are in jpeg format) Now that's a scary difference! Look at how much blurring happens and the complete loss of interlacing artifacts which you usually really want to see to check whether footage is interlaced or progressive or whether your de-interlacing did its job correctly. QuickTime's default settings is by far the worst of the two. Windows Media Player will just half the resolution (which also looses interlacing information etc.). You want a fix? Fix for QuickTime Unfortunately this will only work if you have upgraded to QuickTime Pro. The free version does not allow changing the needed setting.
basis. So you will need to do this again for each file. You have an option to save this preference with your file (QuickTime player asks you to save changes when you exit) so it will stay enabled for that specific file. If you do not save it you will also need to re-enable it when you open the file again. Fix for the new Windows Media Player (wmplayer.exe) This player comes with newer Windows versions like XP and probably Windows 2000 as well.
This player comes with older versions of Windows like Windows 98.
As indicated the fix only works with QuickTime Pro and must be done for every file. Windows XP also has the older Media Player installed and it looks like changing the setting in one program effects both. The screengrabs came from a test Kaku Ito shot with an XL2 camera and are being used with his permission. You can view the original movie in the following thread: http://www.dvinfo.net/conf/showthrea...threadid=31215 Thanks Kaku! If you want to see the difference uncompressed you can download the following BMP files (1.3 MB each): Normal playback (uncompressed) High Quality enabled (uncompressed) |
Re: DV playback looks bad? Go High Quality!
<<<-- Originally posted by Rob Lohman : To the best of my knowledge this problem does not happen on the Mac platform -->>>
Actually Mac QuickTime files also default to low quality playback (or at least they have on all the versions of QT Pro that I've used, but I don't have the newest). There's a little free app available on the Synthetic Aperture website as a free download which lets you drag and drop files to enable the high quality playback flag. Even at high quality setting, I find DV looks significantly worse on my computer monitor than it does on an NTSC screen. |
As boyd wrote, the mac does default to lower quality playback using quicktime. If you're not into free plug-ins.....Robs procedure for hiQ on QT windows is the exactly the same on the mac.
Barry |
Thanks guys! I've updated the post to point to your posts for Mac info.
Yeah, I usually just go to the movie properties and manually set high quality myself also. But note that Synthetic Aperture freeware is not a "plug-in." It's a small stand-alone application. You just drag the quicktime file to its icon, high quality is enabled, and the program exits. Have never really put it through its paces though myself, other than trying it once or twice.
thanks boyd...wasn't dissin' the hi-qual program...although it doesn't seem to work on my machine...I just wanted any unaware macUsers that they could set it themselves...but back to Synthetic Aperture hiqual...I'm running 10.3.4 on a g5, QT 6.5.1...what are you running?... cause when I drag a movie over the icon...nothing happens.
Hey, diss away, I have no agenda :-) Like I said, I never really made much use of it, but just remembered it after reading Rob's post. I just downloaded from the link I gave. Took a short QT file and dragged it to the HiQual icon. You see quick zoom rectangles as the program opens and closes. That's all that should happen. But if you then try opening the movie file in Quicktime Pro you'll see that the high quality box will be checked.
Does this not happen on your G5? Entirely possible it isn't compatible, the program was written in 2002. But it works fine on my G4/1.25 under MacOS X 10.2.8 with Quicktime 6.3 pro (I'm still running FCP 3 and recall reading about problems with it under newer versions of QT, so if it ain't broke... ;-) |
My guess is it's not compatible with 10.3...you can click on the icon, and it tells you to.....wait a minute....ok...my bad..... it works with .mov files...but it doesn't work with the .dv file that kaku posted earlier. I had tried several times with it, but didn't think to try something else....jammin!
BG |
What's a .dv file? Is that a DV stream like iMovie uses? Yeah, I was using a .mov Quicktime file compressed with the DV codec, as captured in FCP without any alteration.
I don't really know the difference between a .dv and a .mov...the dv file is what I got when I downloaded kaku's file...it opens and acts like a .mov in QT...and i have seen them before...I tried renaming it, but it didn't make a difference to hi-qual. I noticed that the data rate on kaku's file was 6.8 mb per sec...doesn't that sound high...I thought DV was 3.5 mb per sec...
Barry |
My guess is that .dv was his own shorthand for something because I think real extensions have 3 letters. Actually the extension shouldn't make any difference on the Mac. And the existence of .mov doesn't tell you what the codec was, just that it's a Quicktime file.
Boyd, no it's not my own shorthand.
.dv is a native dv stream codec within QuickTime instead of Apple's own "not really the same" dv codec. So I thought I should provide it as close as naitive dv stream. I don't know if it is effective yet, but you all know Apple tends to try to set its own standard, becoming like Sony a bit. So, I would rather provide the file as close as "industry standard". I regret to say, as long as I'm using Final Cut Pro HD, it would be not the same as industry standard. |
I think you aren't entirely correct on that Kaku. What happens
(as I know) is this. The DV stream comes from the camera and if you capture it is a .DV file this stream is one-on-one copied to the file. The difference with QuickTime .MOV and .AVI on Windows is that a wrapper placed AROUND this data so players can read it more easily. The data is NOT altered (with multi channel audio it MAY be shifter around in place, but the content itself is NOT changed). So a DV AVI, QuickTime DV or native .DV is exactly the same content wise. The reason why the Mac SA program doesn't work with a .DV file is that it can only change this setting for a .MOV file since a .DV file (which is JUST the basic stream) does not have a HQ property to set. The wrapper .MOV format does! However, when playing the .DV in QuickTime the player allows you to set the option since it is basically a codec setting. Has nothing to do with the original data. Hope this explains some. |
I see. But I read someone's article explaining QuickTime's DV codec is loosing some signal characteristics slightly from original DV stream.
QuickTime and Final Cut Pro improved its quality when they updated both a year ago(?), before that, the DV video quality on FCP was not good, but Apple still claimed as native DV. You can clearly tell Avid XpressDV and Adobe Premiere are not seem to loosing much from native DV stream, but since Apple want to say everything is standard quality and running real time all the time, they must be tweaking the codec a little. What do you think? |
Each DV codec is a little bit different, probably both in quality and
efficiency. On modern computers this shouldn't make too much of a difference. And since native .DV on a Mac plays with QuickTime as well I can't imagine a different codec is being used when the DV stream is encapsulated inside a .MOV file. |
