GlobalMediaPro Battery with SWIT charger
Hi all,
Do you think that the following battery and charger combination is compatible? I already own the SWIT charger and want to get a GlobalMediaPro v-lock battery. Battery https://www.globalmediapro.com/dp/A2...Battery-190WH/ Charger https://www.globalmediapro.com/dp/A0...table-Charger/ Thanks a lot, Chris |
Hi Chris,
Normally this battery will work on your SWIT charger. I do not see why it wouldn't work. I know a cameraman that uses an older model of the batteries you are mentioning on a Sony charger. These days you can mix most batteries and chargers randomly without any problems. I use Sony and Omega Power System V-Lock batteries on a Sony charger. |
Did you ever find out?
Hi Chris,
Did you ever prove that Global Media batteries can be charged on a Swit charge. Regards, Peter |
| All times are GMT -6. The time now is 05:34 PM. |
