-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Sony DSR 450 - no tone? (https://www.dvinfo.net/forum/open-dv-discussion/238720-sony-dsr-450-no-tone.html)
Neil Corbett July 9th, 2009 04:26 AM
Hi,
I'm using a Sony DSR 450 and noticed that it doesn't give out a tone when I record coloured bars. Is this not a feature on this camera? There's probably a setting I'm missing, any help finding it would be appreciated.
Thanks.
Neil
Ben Longden July 9th, 2009 04:37 AM
I use the 570, the 450's immediate predecessor... If you go into the menus, you have the choice of tone or no tone with the bars.
Ben
Neil Corbett July 9th, 2009 04:53 AM
Yeah, i've been through the menus and the manual, and its just not as obvious as it should be. I can change the type of bars but seemingly nothing about the tone. it must be there somewhere...
Shaun Roemich July 9th, 2009 08:00 AM
Have you switched the Channel Selector to Internal (or whatever the "nose" mic is called)?
Neil Corbett July 9th, 2009 09:05 AM
not sure what or where that would be.
i've tried flicking between rear and front mics, which afected tone on our DSR 500, but that doesn't help on this model.
Shaun Roemich July 15th, 2009 05:49 PM
1 Attachment(s)
All right. Downloaded the owners manual PDF. It's a menu item.
Under AUDIO
AU SG(1KHz) is what you want to turn on. See attached.
Page 86 of the owners manual.
Ben Longden July 16th, 2009 08:01 PM
Originally Posted by Shaun Roemich (Post 1172215)
AU SG(1KHz)
Like you said... its NOT that obvious.
Ben
Neil Corbett July 17th, 2009 07:02 AM
That worked!
Thank you very much for going out of your way to find that. I appreciate it.
Shaun Roemich July 22nd, 2009 04:11 PM
Neil: you're welcome!
