-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Broadcast Specs (https://www.dvinfo.net/forum/open-dv-discussion/238667-broadcast-specs.html)
G. Lee Gordon July 8th, 2009 10:34 AM
Broadcast Specs
So I don't sound like a total idiot when I approach a station. What is the proper protocol / etiquette to get a stations specs for broadcast? Who/What department is the proper person to contact?
Ben Longden July 9th, 2009 04:47 AM
Try the chief cameraman or the chief engineer..
Ben
Ervin Farkas July 9th, 2009 10:57 AM
Normally, anyone working in Master Control should be able to give you that info.
Some stations have it on their website.
Kevin McKendree July 12th, 2009 02:13 AM
I would call up and let them know about your project and that you would require broadcasting specs. Anyone working Master Control should if not I would try the Chief Engineer.
Jim Snow July 13th, 2009 11:33 AM
You will give yourself more latitude if you try to find out what they will accept as well as what they prefer. They usually have some latitude depending on what the footage is for.
David Barnett July 15th, 2009 08:24 AM
Are you sending in a commercial to them? If so, the sales team should be able to obtain that.
