-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Vx2000 or XL1 again... (https://www.dvinfo.net/forum/open-dv-discussion/1550-vx2000-xl1-again.html)
Chris Hurd April 14th, 2002 11:27 AM
The trick to using Frame Movie mode is to keep your camera movements to a minimum... slow careful pans, etc.
Regarding a film look, you won't get this from any certain shutter speed but rather in how you choose to light your subject.
Joe Redifer and I like to debate this particular topic... my viewpoint is only one opinion... but I believe a film look is all in the lighting and also filtering.
I think you should start with concentarting on basic framing and carefully composing your shots; ultimately the content and the way you present it is far more inportant than making it "look like film." Hope this helps,
Don Donatello April 14th, 2002 04:11 PM
"I have finally bought the XL1s :) "
"I tried out the frame movie mode. The video produced is kind of jerky/blur. I am not sure how to describe it. The movement is not that fluid i think. "
24fps is more "jerky" ... 60i ( normal video ) is much smoother .. the 30fps frame mode is in-between ....
I"s this what it's suppose to do? Or have i done something wrong? "
that's the way it is !
"Which is the best shutter speed to shoot on to achieve a more filmy look?"
IMO 1/60 th of second ... for special FX use higher IE: you are moving with subject in foreground and you want background to be JERKY ( stacatto) then use 1/1000
"Need some advice as to what to adjust to make the video the best looks. "
IMO it's the LIGHTING .. look over at the production stills at
www.rocketchicken.com the movie was shot with XL in 16x9 mode ( shot by DP that shot "the sixth day") ..each shot was lit.
they tshot this movie as if they were shooting FILM ...
IMO use frame mode , 1/60 shutter, light each shot ( if you move the camera - then you re-light for the new framimg ) , do NOT zoom during shot, use your zebras to get best results ........
Michael Chen April 15th, 2002 04:01 AM
Thanks guys.
I am new to DV, and definitely new to xl1s.
I got a couple of more questions but i'll ask them bit by bit :)
Do not want to get too confuse with too many infos.
1) When i put the video mode in 16 x 9 mode, how do i make the black bars appear? When i transferred the video to computer, the black bar is not there. So what does that mode do?
2) I did a short film with my friend's camera a couple of weeks ago. Everything is fine, but when i convert the video format to vcd mpg format, the video quality has been adversely affected. I need to transfer the video to vcd format so that my friends can watch them on tv, so how do I prevent the video from the adverse effect?
thanks for helping !
