-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Super8 film to DV (https://www.dvinfo.net/forum/open-dv-discussion/14971-super8-film-dv.html)
Mike Calla September 25th, 2003 01:38 PM
Super8 film to DV
Before I go out and spend some cash on tests I’d like to find out if anyone has had Super8 film transferred to a digital format? This topic has been covered before but only for archiving family movies. I would be doing this for a commercial production and wondering how the conversion stands up. ie: color saturation, contrast ratio, basic tech info. I live in Toronto, Canada, and we have a reputable Super8 transfer house, but I’d like to here how your transfers have gone before I commit.
MikeC
Jeff Donald September 25th, 2003 01:53 PM
I've had clients go to Super 8mm and I was not impressed. If you can at all afford it, go to at least 16mm. Super 8mm looked very grainy. The client was not happy and wished he had spent the additional to go to 16mm. Most transfer houses should have samples for you to view. Maybe my client used a cheaper transfer house.
Daniel Kautz September 25th, 2003 09:30 PM
Ummm... Jeff
I was just browsing through and read this thread. I believe you got Mike's question backwards. <g> He's asking about transfering Super8 film TO Digital Video.
Regards,
Dan Kautz
David Hurdon September 26th, 2003 07:13 AM
Mike, I'm sorry to jump in without an answer but I'm in Toronto too and need some film to gigital transfers myself. Would you mind sharing the name of the house you know locally?
David Hurdon
Mike Calla September 26th, 2003 08:20 AM
Sure David it's
Exclusive Film and Video
http://www.exclusivefilm.net
Local: 416 598-2700
Fax: 416 598-0766
Toll Free: 1-888-497-9922
101-F1 Niagara St.
They work mostly in super8 but I think they also do some blow ups to 16 and 35mm.
Glad I could help
MikeC
Alex Taylor September 26th, 2003 01:21 PM
I've seen dozens of Super8 -> DV transfers and they look great. We just project them on to a screen and set up a DV camera beside the projector set to 1/30. It looks just as good as the projection.
Mike Calla September 26th, 2003 01:33 PM
Thanks Alex
I realise that it can be done with great results but I'm hoping that transferring via a telecine will yield even greater results. However I'm taking your word on it and I'm borrowing my parent’s projector/screen and a couple reels to see what kind of results I get. I’ve gotten some good info already in the forum archives with respect to adjusting projecting speeds to cope with my cameras frame rate/interlacing issues. We'll see.
MikeC
Alex Taylor September 26th, 2003 01:46 PM
Good luck Mike! Let us know how it goes.
If you want a few examples of this method, check out this site: (http://www.giftsfilms.com/onscreen/c...gory_code=SUP8). All those films were done in Super8, transferred to DV and edited digitally. May I recommend Romanticide and Intemperance :)
Don Donatello September 27th, 2003 12:03 AM
i've shot super 8 for sections of commercials and transferred on ranks. kodachrome 40, ektachrome160 , tri x B&W .
i have not shot any of the super 8 negative stock
if you are trying to cut cost by shooting super 8 hoping for it to look like 16/35mm .. IMO you will not be satisfied.
however if you are looking for a film look that has a bit of grain, a little soft or to look different then your 16/35/video it might please you.
Mike Calla September 27th, 2003 08:25 AM
Don
You’re right, I wouldn’t be shooting Super8 instead of DV-only to supplement it within a TV spot. Right now we are looking to shoot in PlusX Reversal B/W, hoping that this slower speed film will minimize graininess. The camera we are looking at renting has the ability to shoot NTSC drop frame. I imagine this would be the best way of negating any pull-down issues during transfer? In fact I have to make sure the lab can transfer in the frame I choose to film in. Another thing you mentioned - “negative stock”. I did some searching and found out Kodak has now started to sell Vision 200T Super8 stock. A few labs in Toronto will process the stock but will not make working prints. Do have any idea which lab can do this in the US or Can?
…Alex
I viewed many films on that page including your suggestions and although I found the content quite interesting (in fact I had already seen one entry on ZEDtv here in TO), I found the quality to be very poor. Right now I will attribute this to Real Player and streaming media (I dread web media), but it did make me stop in tracks briefly. My only solace was viewing my parents old Super8 reels. I haven’t seen a projected print in a long time and forgot how good it could look. The way it handled light with a velvet glove, how good the colour saturation was and to my surprise how detailed the images were. And these films were 30 years old. I can already image how good I can make it this stuff look in a controlled environment with a manual camera and real lighting fixtures. I can’t wait to shoot some test reels and see how they turn out.
MikeC
Dean Sensui September 27th, 2003 12:12 PM
Mike...
Take a look at this website:
http://www.moviestuff.tv/
He sells film transfer equipment and he also does film transfers as a service. Of interest is one that will step thru frames at a relatively slow rate. There's a switch that has Premiere grab a frame into the computer's hard drive. This eliminates sync problems and gets a very nice transfer.
He also offers test transfers if you're interested in seeing the quality level.
Hope this helps,
Dean Sensui
Base Two Productions
Don Donatello September 28th, 2003 02:37 PM
pro 8 offers ASA 50, 100, 200, 250, 320, 500, 800 negavtive stocks and they transfer on RANK to mini DV and other formats.
http://www.pro8mm.com/us/film_frm.htm
i do not know anyone that workprints it .. it is mostly used to either transfer direct to tape or blow up to 16/35 or data files made ...
negative requires EXTREME care as any dust will show up as WHITE and it scratches easy ...avoid handling it ..
reversal films are very forgiving on dust and handling it ..
if you shoot film at 24fps and transfer to NTSC tape PULL down will be added ... up to you if you want them to transfer using drop frame or non drop TC - there is no difference to frames or amount of frames - it all ends up on NTSC tape at 29.97 ...only difference is how it is counted.
i was going to post a clip of super 8 and 16 mm but after i made a 512K stream you can't see the difference between them . so i'm not posting it ....
Richard Alvarez September 28th, 2003 03:59 PM
If you are trying a "poor man's telecine" - that is, shooting off of a screen... it will work best if the super 8 was shot at 18 frames a second - not 24. The reason is that you will speed up the projector to twenty frames, the three-bladed shutter in the projector will create 60 images a second... and you have sync.
With 24 frames per second, you are better off going through a proper pulldown. Moviestuff is good, so is super8sound in Burbank.
