-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Shooting the sun (https://www.dvinfo.net/forum/open-dv-discussion/14813-shooting-sun.html)
Jeff Altman September 21st, 2003 07:30 PM
Shooting the sun
Will I have to take special precautions in shooting the sun? Can I damage my camera? Thanks!
Boyd Ostroff September 21st, 2003 07:42 PM
Re: Shooting the sun
Lots of discussion on this already. Try this for starters...
http://www.dvinfo.net/conf/showthrea...ight=shoot+sun
Glenn Chan September 22nd, 2003 04:17 PM
The manual probably tells you not to shoot into the sun. This is probably because you can burn out your pixels that way. Anyways, you should use a neutral density filter to protect your camera and because cameras don't do well when it's really really bright.
You can also get a graduated ND filter. It darkens the top more than the bottom. This can reduce the contrast between sky + ground.
