-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   DV to Beta SP (https://www.dvinfo.net/forum/open-dv-discussion/146479-dv-beta-sp.html)
Brandon Carter March 24th, 2009 07:28 AM
DV to Beta SP
What is the recommended set up to output my dv from FCP to Beta SP(beta recorder)? I am using a Mac Pro.
Dean Sensui March 24th, 2009 12:22 PM
I use a Decklink card, going to the Betacam deck via component connectors.
There's an RS-422 port which provides frame-accurate deck control.
You'll need to get the PCI-e version of the card. The Decklink Extreme is a good choice, since it provides SD and HD I/O.
Brandon Carter April 10th, 2009 09:42 AM
Thanks for the info. So all I need is the card and connectors? Also, what is the difference between the UVW 1800 and 1400? Are there any other decks to consider? Thanks.
Shaun Roemich April 10th, 2009 10:01 AM
RS-232 vs. RS-422 control for one. You want RS-422.
You MAY want to try and find a BVW-75 used. The things are TANKS and address all four available audio tracks (longitudinal and AFM hi-fi tracks) instead of just the longitudinal tracks the UVW series addresses.
Dean Sensui April 10th, 2009 01:20 PM
You'll need:
-- Two three-conductor bnc cables to get component in and out.
-- A 12" BNC cable to jump from video reference-in to the y-in to sync the blackburst of the deck with the card.
-- Four XLR cables to connect audio in and out to the Decklink card or to your mixer.
-- A nine-pin RS-422 "straight through" cable for deck control.
-- A Y/C or composite video cable for monitoring the deck. If you want an on-screen menu for the deck you'll have to use a composite cable.
I haven't used a 1400 so I can't say what the differences might be.
Brandon Carter July 21st, 2009 07:27 PM
bringing up old topic
Thanks for the info in this thread and over at the cow. I think I have it now. We purchased the Uvw 1800 and a decklink extreme hd card. Ok, now I am trying to hook my panasonic vtr into the card for capture. Its my understanding, that I will have to remove the input BNC's from the beta sp and use a BNC to RCA adapter with the rca's plugged into the vtr. Does this sound right? Thanks.
