-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   white balance on a sunny day (https://www.dvinfo.net/forum/open-dv-discussion/118376-white-balance-sunny-day.html)
Dom Stevenson April 2nd, 2008 06:08 AM
I'm off to Italy with my XHA1 and i hear the weathers very nice at the moment.
A couple of questions:
When white balancing on a sunny day, should the balance be done in the shade or in direct sunlight?
Is it ok to white balance with a polariser on?
Thanks for your time.
D
Shaun Roemich April 2nd, 2008 08:11 AM
When white balancing, use the dominant light source. If it's more cloudy than sunny or you're shooting in the shade, I'd go for shade. The caveat there is that all bright sun lit objects will then be overly orange. It depends on whether you prefer warm or cool image temperature. The other option, if you have colour correction gels with you, is to white balance in direct sun on a white object with an 1/8 or 1/4 day gel over it. That will split the difference between direct sun and shade.
If you have access to a field monitor, use it. If you avoid shooting a subject under shade and direct sun in the same shot, you have some latitude in post to colour correct.
With cameras with an A/B switch for white balance, I program A with direct sun and B with overcast/shade and switch back and forth as necessary.
And yes, white balance with the polarizer on.
Jim OBrien April 2nd, 2008 12:51 PM
White balance to lighting situation of your main subject. If they will be spending most of the time in the shade, then balance to that. If it's 50/50 then I tend to balance for the shade since I find the warm glow in the sunny areas more pleasing than the cool blue of the shady areas when you balance to the sun.
Dom Stevenson April 2nd, 2008 03:58 PM
Ok, thanks guy's . I enjoy sorting out stuff in Apple's Color so i'll be ok either way.
I agree a warm sun is preferable to a cold shade so i'll bear that in mind too.
Cheers
Dom
Bill Ward April 2nd, 2008 10:55 PM
I don't have a scientific reason why, but I would have said to balance filter neutral--whichever filter you might be putting in front of the lense.
To me, balancing with a filter on always tends to remove most of the effect of the filter. With the vast difference a circular polarizer can make as it rotates, I'd be reluctant to trust the WB.
I'd also recommend a shade balance if there is much of a chance of cooler color temps in the shot. If your camera reads more than about 6500 degrees on the color balance, though, the sunshine will be very warm looking. I'd try to find a bit more direct daylight to add in to the color balance. If you're trying to make the early morning sunrise, or late in the day sunset really pop with color, look for something in the 8000 to 10,000 degree balance range.
Shaun Roemich April 3rd, 2008 01:38 PM
A polarizer works differently than, say a warming filter, in which case you should indeed remove the filter first before white balancing. The polarizer works by "aligning" streams of light, not changing the quality of the light. If the polarizer is not truly without colour cast (as an ND filter is), it may impart a colour cast, which should be negated by white balancing.
HOWEVER: this is purely an academic discussion. Try it both ways and see if you can see a difference or not. If you have a quality polarizer, it shouldn't make a difference. If you paid $15 for it brand new... well...
