-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Widescreen 1.2 to square 1.0 conversion? (https://www.dvinfo.net/forum/open-dv-discussion/105546-widescreen-1-2-square-1-0-conversion.html)
Nathan Quattrini October 13th, 2007 08:37 AM
I have a 720x480 project in Premiere with 1.2 PAR, but the program I`m making the graphics with doesn`t have a PAR option, just dimensions. So if in all technicality the 1.2 was converted to square pixel dimensions what would it be? 760X400 or something?
Boyd Ostroff October 13th, 2007 08:59 AM
If using square pixels then the size should be in either the 4:3 or 16:9 proportion depending on the format. So for a 4:3 image if you want the height to be 480 pixels then the width would be: 4 / 3 X 480 = 640, resulting in a 640x480 image.
For 16:9 the math is the same; if you want the result to be 480 pixels high then you get 16 / 9 x 480 = 854 (rounding up since you can't have a fractional pixel :-) This would give you a 854x480 image.
If you want a different height image you can just plug it into the formula in place of the 480 above.
Nathan Quattrini October 13th, 2007 09:12 AM
woah...i didn't know the math was so simple. Thanks so much!
*EDIT*
hmm still a little 'short' on either side, but at least i have a guideline now, thanks
