-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Digital Juice (https://www.dvinfo.net/forum/non-linear-editing-pc/79986-digital-juice.html)
Peter Higginbottom November 19th, 2006 01:16 PM
Digital Juice
Hi
Just got Digital Juice editors toolkit 2 part 2 Off E-Bay.
Unfortunately I cant get my head around making them work in Premiere 6.5(Pal system) using a Matrox RT.X100, must be My age I guess.
Any suggestions please. I got one to work, sort of.
Animated wipe of a remote control, but the background wasn`t transparent, tried alpha channel etc, no joy.
Regards.
Peter
Sheila Ward November 19th, 2006 04:43 PM
Try the support over at Digital Juice:
http://www.digitaljuice.com/support/default.asp
Here's a knowledge base article on transparency and Premiere 6.5: http://www.digitaljuice.com/support/...tail.asp?tid=8
Jim Montgomery November 19th, 2006 06:22 PM
You have to use the Juicer software to render out from the tool kit. I am pretty sure it is a free download.
Jim
Peter Higginbottom November 20th, 2006 11:15 AM
Hi
Thanks for the tips, I can see a steep learning curve looming, lol.
I`ll need to look for a basic "Getting Started" with Juicer etc.
Regards.
Peter.
Jim Montgomery November 20th, 2006 11:49 AM
Peter
Juicer is really simple. Load the software, insert your Editors Toolkit in the drive, got File --> Install Previews and this will load the Toolkit. Then all you do is select the file you want to use, in the product browser, drag it into the batch window, select your option and destination in the Render Settings and then click on render. Your file will saved to the directory you chose with alpha and such ready to use.
Jim
