-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Problem with Adobe Encore (https://www.dvinfo.net/forum/non-linear-editing-pc/64443-problem-adobe-encore.html)
David R. Warwick April 5th, 2006 04:58 PM
Hey, all
I'm experiencing what seems to be an error with Adobe encore. Hope you can help.
I've just finished editing a small film in Premiere Pro and now want to burn it to DVD. My method for doing this is to export the film as an AVI file onto my hardisk and then import it as an asset in Adobe Encore where I can add menus, etc, before burning.
The exported AVI file (viewed through windows media player) exists exactly as I finished it in Premiere, however as soon I import it as an asset in Encore all sorts of very unwanted changes happen to the titles - for example the title of the film, 'drags', fails to appear when it is supposed to, then flashes on and off almost instantaneously; also at the end some of the credits fail to appear. These unwanted changes are apparent in the DVD preview, and in the burnt test copies.
I've had exactly the same sort of problem with titles in trying to burn a past project to DVD using this method. Because i was working to a deadline I had no choice but to make some alterations and work around it. It would be ashame to have to make such sacrifices again.
Has anybody else experienced this? Can anyone explain it?
Dave
Trond Saetre April 6th, 2006 07:46 AM
Have you made any changes to the settings in Encore?
I do it the same way as you do, export an avi file from Premiere and import that avi file to Encore. But I have never experienced your problems.
(I use Premiere 2 and Encore 2 now, but used 1.5 earlier)
One time I have had trouble, but that turned out to be an error in the encoding from Premiere with one single avi file.
The solution that time was to encode the avi file again with Premiere.
Mike Teutsch April 6th, 2006 07:58 AM
I don't know how to fix this particular problem, but you can make a DVD right in Premiere. Just choose to export to DVD. I do that once, then make all of my copies in Encore DVD.
Just a thought.
Mike
Wes Coughlin April 6th, 2006 08:04 AM
you could try exporting mpeg2-dvd directly from premiere and then bring it into encore. Since encore will encode your avi as an mpeg2 for dvd, i find it to be quicker and more effects usually to transcode through premiere's media encoder.
David R. Warwick April 6th, 2006 10:38 AM
Thanks for the suggestions. All helpful. It's a bizarre glitch (if it is a glitch). Maybe it's just a case of experimenting with exporting and importing settings.
Dave
