Cheapest camcorder with firewire to analog tv output?
If I want to monitor my work thru firewire to analog rca tv. what is the cheapest way?
Firewire output -> Analog RCA TV I saw on a ebay a defective Sony TRV19, defective defective playbck and defective optics. it has a D/A passthrough selling for $150 worth it? |
The TRV19 can't do analog --> DV, although it should be able to do the other way around.
The TRV22 can do analog --> DV, for turning analog material into DV. 2- Don't you already have DV camera? |
If you only need to transcode analog <--> firewire (and not record to tape) then you may be better off with something like this:
http://www.bhphotovideo.com/bnh/cont...ughType=search This box also has s-video and component video, so you have a much better quality connection to a good monitor than a cheap camera will offer (will probably be limited to composite video). It also does both PAL and NTSC if that's ever needed. |
| All times are GMT -6. The time now is 01:41 AM. |
