-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   An HDV newbie question on capturing (https://www.dvinfo.net/forum/non-linear-editing-pc/57839-hdv-newbie-question-capturing.html)
Carlos Manuel January 9th, 2006 05:23 AM
Hi all,
My NLE is a SD one: Targa3000 + PP6.5 + Combustion4
I will shoot with a Sony Z1E (PAL) a corporate video.
I will shoot HDV and downconvert in the camera, and output a PAL squeezed video, later on.
What will be the best video signal that I get:
- from the YUV out, and then captured in YUV uncompressed or MPEG-I frame at 50Mbps
- from the I-Link in DV quality.
My question comes because I'm not sure that the YUV out comes from the DV signal or not.
I mean, when a tape plays back an HDV signal, what signal comes "directly" from the tape: the DV or the YUV ?
Witch one is generated from the other ?
Because if the "main" signal is the DV, there's no point in capturing in YUV (file size is BIGGGGGG)
Thanks for any input.
Carlos
Jason Hamby February 8th, 2006 11:36 AM
Think of it this way, once you lay to tape, your footage is now HDV with mpeg compression. So YUV out or I-link just becomes the transfer cable. So I'd stick with i-link if you're transfering from tape.
However, if you can do a 'live capture' and record directly to your NLE via the YUV out, then you're bypassing the HDV compression and you can get an VERY nice uncompressed capture. But this requires a fancy setup (dual opteron, 200 mb/s raid, etc...)
Simon Antoniou October 18th, 2007 12:51 PM
Will a HDV timeline/footage be down converted if I record straight back to Mini DV tape or will it be full resolution?
Can this be done on either Avid or Mac?
