HDMI Input to PC to Play Video
Hey all,
I'm looking for a way to input HD video via HDMI into my PC, and then play the video in a window real time. I don't need to record it - I just want to be able to play it on the monitor. Does anyone have a hardware/software solution they'd recommend for this? I have searched the forums, but it's a hard thing to narrow down with search terms. Thanks in advance! |
Re: HDMI Input to PC to Play Video
Thank you, and I should have been more clear. I was pretty sure that I would end up with a device that doubles as a capture card, but I'm looking for a recommendation for a specific card based on a couple things:
1. I don't care how well it does at actually capturing, so long as it plays 2. It comes with software that allows playing video in a window without excessive overhead given to recording (as in, I don't want to open Premiere and play this in a Premiere capture window, I just want a separate stand alone window with the video playing) I'm also, of course, open to having a capture card and third party software that plays it in a window, in which case I'm looking for a recommendation for the specific third party software. Thanks again. |
You can use VLC to view a capture device (Media > Open Capture Device.)
I recommend the Magewell capture cards since they require no drivers. They enumerate as a webcam. |
Great tip on VLC! I didn't know you could use it there, but that solves a lot of problems, really.
The Magewell cards look relatively pricey. I might suck up the extra drivers for a couple hundred dollars ;). Thanks for the input! |
INOGENI makes a device for what you want to do: https://inogeni.com/4k-usb3-0/
Another from Magewell: https://www.amazon.com/dp/B01N16ZM2M..._t2_B01AQ7HQ62 Similar device from Epiphan: https://www.bhphotovideo.com/c/produ...k_usb_3_0.html Here's a video demonstrating its use: |
Great, thanks for those.
There is a device that's designed specifically to do what you want. No capture card needed and won't slow your computer down. Simply plug in hdmi cable and your good to go...
a TV |
I got a 19" Insignia TV at Best Buy about a year ago, have been surprised how good it looks. Cost me $80.
