Question about mulitple video card setup? (not a which one should I buy question)
I'm blueprinting a new system for myself, and I've been out of the computer, and editing loop for more then a few years. Built many systems for use as DJ night club music systems, and only 1 editing box, back then. Any how, as I said before, I am blueprinting out a new system and I was wondering about the following.....
Is the purpose of multiple video cards simply to run multiple monitors? Or with the new GPU stuff for video editing,CS5 specifically.(At this point I don't yet know all the terminology, so I'm sorry if I am using the wrong term for something else), do multiple cards spread the work across all the cards, to allow faster work (again don't know if my terminology is correct)? Thanks for the help, Jeff |
Randall is correct; for editing with CS5, applicable or hackable GPU's with 1GB+ of ram (MOST if not all of these cards can run 2 monitors) accelerate GPU enabled effects and speed up rendering times (export is still a matter of debate but it is minimal if at all) and enable the Mercury Playback Engine which is MUCH faster than software render alone.
You only need one CUDA/MPE enabled card to get the acceleration out of CS5; multiple cards are not supported. I doubt we will see this feature until CS6 (which is a shame, because if they could render and use graphics cards' DDR5 ram and insanely high core counts and clock speeds, we could have MUCH better performance with say 4 2GB DDR5 CUDA/Fermi cards doing the work versus even the venerable i7 980X 6 core (12 with HT enabled). |
