PC Build suggestions
Getting ready to have a new computer built. I will be using CS5. The guy building does not have any DV experience. And I am a computer retard. So I would appreciate suggestions. I have about 3k available for the build.
Thanks for any help |
I found my suggestions from quite a few forums when i built my PC last year, here is the built i achieved at the end and happy with it.
Gigabyte Mother board DX580 i guess I7- 920 processor 12 GB DDR3 Ram 512 MB - ATI Graphics card all HDDs should be minimum 7200 RPM In case you get the Velociraptor with is 10000 RPM for the OS and the editing program it would work far more effeciently. A Decent Full HD monitor - guess now the market can give you many choices in this. Do ensure that you have a good SMPS since the power requirement is big , i use it without overclocking anything, however you can overclock and it should fly Once you built this up there are some things to remember 1) You now have a 64 bit Hardware and CS5 is fully 64 bit software 2) Use a full 64 bit OS, i use the Vista 64 bit This combination i have seen works damn smart at my end to edit HD. All the best with your build, hope the above helps and yes it would be under the budget you have. |
Watch out for the graphics card - you need cuda enabled Nvidia card to support CS5 for the mercury playback engine in PremierePro - check on Adobe website for supported cards - with your budget - get SSD system drive - a mobo with sata III as well as usb 3 - and buy a 6 core i7 then clock it - that way you'll be well set for the future !
Paul |
I agree with Paul's points. With a $3K budget, you can build a really capable box:
MB of choice, ASUS, Gigabyte. 6-core i7 processor 24GB RAM (PPro CS5 loves RAM, and if you use AE you'll get longer RAM previews -- expensive, yes, but go for it) CUDA-capable nVidia-based graphics card with at LEAST 1GB (presently folks seem to find the 460, especially variants with >1GB, to be in the value/dollar sweet spot with a simple hack that you can find elsewhere on the forum) SSD for your C: drive; opinions differ but I think an SSD is a better choice than any HDD for your OS/Programs drive 2 or more fast HDD to RAID for your working files Load up Win7 x64 and CS5...enjoy! |
The problem with using an SSD for your programs as well as the system files:
Some programs eat up hundreds of GB of space during a typical install. This means that an SSD that will hold even one such program will be astronomically expensive. And most of the moderately-priced SSDs do not have enough available space to hold an entire production suite in addition to the system/boot files. To give you an example: A 1TB SSD costs a whopping $1800 by itself - whereas most of the sub-$200 SSDs offer less than 100GB of space. A large single SSD would have left very little room in a $3000 budget for the rest of the components. |
Decent SSDs can be had for $150-200 these days. Unless one has some other reason for having huge capacity on their OS/Programs drive, IMO there's just no need to do other than SSD. EDIT: Did a quick look up on system requirements in GB: 20 = Win 7 x64 24.3=Adobe MC 03.5 = MS Office 2010 Pro Plus (for those that do other than edit with their machine) ------- 47.8 GB Add another 10 GB for another gaggle of apps and it all still just fits on a 60GB drive. Get 80+ for headroom and you're in good shape. |
One of my most frequently used programs takes up all of 400GB of space (yes, 400 GB, not 40 GB, due to extremely sloppy code) - and it cannot run from any drive other than the boot/system drive. So for my particular use, then yes, an SSD of that capacity will be astronomically expensive.
Randall, then yours is a most unusual situation and not applicable to someone doing a PC build for CS5. An SSD is not essential, but is a good addition to a new build for typical editing boxes.
Fair enough, Pete. Although it is not recommended to have any other programs installed on the same PC as the video editing machine, there are some who do it anyway because they simply cannot afford or don't have enough room for a second PC.
Side note from Brandy's original post.
I am building a laptop for same-day edit purposes. I will be using CS5. I have decided to go with HP's ENVY 17 series and I need to decide on a 1tb 7200rpm or 2tb 5200rpm hard drive. The 2tb is $250 more but my budget allows for it. Do I really need 7200rpm? |
Assuming you're working in HD of some flavor, a single-drive system definitely won't be optimal, so the faster the drive, the better. Will your same-day edits require anything approaching even 1TB?
I took a quick look at the Envy specs on the HP site; it is missing one feature that I personally consider essential: a CUDA-capable nVidia video subsystem. That means you will not be able to enjoy CUDA acceleration of commonly used effects. If I was buying this machine for CS5, here's what I'd get from the available options (not taking the time to price it out, but I'm sure it would be expensive): - fastest processor option - 8GB RAM - SSD option for internal drive (it's a combined 160GB SSD and another 640GB 7200 drive - separately, an eSATA drive for my data But again, I'm so happy with smooth timeline editing using the 40 or so CUDA-enabled effects in PPro CS5 that I personally wouldn't buy any machine that wouldn't support it. If you're doing straight cuts with minimal color correction, etc, then it might be ok, though, especially if you're using Cineform FirstLight to minimize your PPro effect needs. |
On this forum I would assume to address people's video editing needs, as this is a video editing forum. I understand that there may be people that tinker and dabble with video on the side and also play games on their machine, but I think that is the exception and not the norm here. |
My first video editing PC will also have to double as my everyday PC so I'm taking forum advice and adding a second hard drive. Question/s:
Does the video edition software go on the video data file dedicated drive or on the OS drive? Is there a 10,000 rpm mechanical hard drive? Can this hard drive be an external without loosing data rate speed? Because this new PC has a 1 TB OS hard drive, I'd like to keep editing my stills there and add a new HD just for video. |
C: drive is OS and Programs. Yes, the WD VelociRaptor is 10K but lower capacity (I think the current version tops out at 600GB) and much more expensive (currently going for about $280). I'd think with little or no expenditure above what a Raptor would cost, you'd be better off to set up a RAID with 3 or 4 inexpensive 7200 RPM drives.
You can use eSATA if you want but if this is the only box you'll be editing on in the near future, I'd recommend just using an internal RAID for editing or storing your files. Both USB or 1394 (Firewire) would not be recommended for editing. If you're not familiar with the various RAID implementations, there are a number of discussions on DVinfo that you can search for. There are a lot of ways to skin the cat. What I do is have a 4x500GB RAID0 for copies of source files and preview files. I have a minimum of two separate archival copies of all source files that are not on the editing box at all, with at least one copy being off-site. So in case of a drive failure in the RAID0 array (and therefore everything on the array being irretrievable), all I've really lost are preview files which my editing software can regenerate. Some folks use their editing box source files as an archive as well; in that case RAID0 would be a really bad idea; a redundant type of array will protect you from a single drive failure and RAID0 won't. Regardless, everyone should have an independent backup (preferably 2 or more) of everything they wouldn't want to lose. |
Thanks Pete. I guess I got a litle ahead of myself today. After asking these questions I went out into the world found my answers. My new computer arrived today and it has one 3.5 slot and one 5 inch slot open so I proptly filled them. I added a 300GB 16MB cache WD 10000 rpm internal (SATA) hard drive and a Pioneer 206 BluRay burner.
I realize the 300G is smallish but I'm just a working class guy with an entry level HD camcorder. If I have to, I'll store files on BluRay disc. Do I understand you correctly? I need to install my video editing software on the C drive and store nothing but my video on the 10,000 rpm drive? Is that how it works? I sure appreciate you input. I've done still for years but video is brand new to me. |
ill put it simply and safely; you have two drives. if its something you do NOT want to lose, keep a copy on BOTH drives or burn them to a DVD/Blu Ray/external HDD. keep your OS and editing software on one disk (C drive) as well as your original 'to be edited' files, and put the 'scratch/output/project' files on the second disk.
and back it all up often! |
Very good. I actually have 3 drives. I have a 600GB Western Digital My Book to back up the system every night.
OK. Time to shut down this old computer and install the new. |
