-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Trouble Capturing audio from XL1 (https://www.dvinfo.net/forum/non-linear-editing-pc/43924-trouble-capturing-audio-xl1.html)
John Travis May 2nd, 2005 09:57 AM
I'm capturing off my XL1 through firewire onto my notebook (through a PCMCIA adapter) using Adobe Premiere pro 1.5. The only problem is I can't get channels 3 and 4 through the firewire (if I watch my tapes on my TV I can get all the channels using the analog outs).
Is it possible to get all the channels through firewire? Do I need a capture card?
Edward Troxel May 2nd, 2005 10:20 AM
Download and buy Scenalyzer Live. It will capture Video+Stereo 1 into an AVI file while simultaneously capturing Stereo 2 into a separate WAV file via firewire.
John Travis May 2nd, 2005 01:46 PM
I tried Scenalyzer, but I'm have the same problem. At this point I'm thinking it's a hardware issue with my capture card, but I'm not sure.
Edward Troxel May 2nd, 2005 02:57 PM
Is it a standard firewire port? If yes, that should not be the problem.
Did you change the settings in Scenalyzer and tell it to capture the "secondary stereo channel if available"? It's a setting in the preferences that must be turned on.
John Travis May 4th, 2005 03:40 PM
Finally figured that out. Thank you. Now it's working. Just have to get used to the program, they don't have the greatest help page.
