timecode in avi files?
anyone know of software that will rewrite an avi file
and embed user selectable timecode into that file? using ppro v1.5. i have some files made from svhs tapes. they have a window burn but that's all. i want to embed timecode into the video stream (like dvcam might) so that it will be readable by ppro. when i've tried the simpler solution of assigning 'premiere timecode' to the files premiere hasn't recognized it. this prompts me to look for a more fundamental solution - embedding. 'premiere timecode' basically is just a start number for the file, not really embedded. also, if i can embed the timecode it would be readable by other apps. thanks, george |
Hello George and welcome aboard (H)DVInfo.net!
As far as I know the AVI container format has no native support for timecode. However, the DV(cam) codec has a substream for timecode indeed. What happens if you export the timeline as a DV AVI, does it get timecode? In theory it should, if not you may need to look for a DV timecode (re)writer (if such a thing exists). |
I seem to remember various utilities that let you change/set the timecode reference in a DV.avi file ... but the only one I know for sure does this costs a few dollars & can be found here:
http://www.baobab.net/softcs.htm It is the 2nd program in the list. If I were to continue searching I'd look at utilities that know how to poke their way around the avi structure ... GB |
| All times are GMT -6. The time now is 06:42 PM. |
