-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Jvc Sr-vs30u (https://www.dvinfo.net/forum/non-linear-editing-pc/36175-jvc-sr-vs30u.html)
Stuart Deaver December 10th, 2004 02:06 AM
Jvc Sr-vs30u
Can somebody tell me if this deck has "locked" audio when converting analog to Digital? And is there anything that I should know about the JVC SR-VS30U for analog to DV conversion?
Mike Cavanaugh December 10th, 2004 11:33 AM
I use mine all the time for converting S-Vhas & VHS to digital. Sometimes I dub a tape to DV, other times I use it as a capture device for my editing system. I also use it for capturing other formats (Hi-8) through the S-Video inputs.
Stuart Deaver December 10th, 2004 11:51 AM
audio out of sync?
Does the audio ever go out of sync with the video when you convert a long program from analog (VHS, S-VHS, 8mm, Hi-8mm) to DV?
Mike Cavanaugh December 10th, 2004 12:18 PM
I've never had that problem. If you are using a monitor off the deck outputs, but are listening to your computer speakers, there is a lag, but it is in sync when captured and output. Try turning off your computer speakers and watching and listening to the monitor (I just use a small TV) On my system they are in sync.
Mike Rehmus December 12th, 2004 09:38 AM
It isn't the deck that determines locked or unlocked audio, it is the format. DV is not locked audio by definition.
Most of the companies have learned to do the audio correctly with regard to syncing with the video. AFAIK, only Canon really were 'out of sync' with the rest of the world.
