Capturing video bottleneck
My setup is XM2 to the only firewire port on my laptop, a 4 pin firewire port, but I want to capture to an external hard drive.
My question is if I use a firewire PCMCIA card to connect the external drive is that the slowest part of the data transfer. CPU 2.7 with 512 RAM. Editing with Vegas 5. IS USB 2 not fast enough for sustained capture rates? What would be the recommended set up for a laptop with only the one firewire port? |
Hi Colin,
Actually USB 2 is a bit faster than standard Firewire 400 so the sustained rate should be more than enough to feed the external HDD. USB 2 is 480mbit/sec and standard firewire is 400. Using a laptop the problems that may(with a big maybe) arise is that the internal data-bus architechture isn't coping with the load of reading fast firewire and putting it on the USB2 bus. But with a modern laptop as yours I don't belive that'll be any probs at all. // Lazze \\ |
I too have a laptop with one firewire port. I capture to a USB2 external drive and have had no problems whatsoever so far, although it's not my main editing system and hasn't had that much work. The specs include P4-3GHz, 512 MB RAM, XP Pro (Media Centre Edition).
Some people might be interested in this real world example, with a twist. Earlier this week I installed the demo of DV Rack from Serious Magic. Using it I captured "live" to the external drive, no tape in the VX2000, and could immediately scrub and play back the resulting DV AVI files. No system issues at all. David Hurdon |
Thanks for that! Made my desion on which external hard drive, based on your guys input. Cheers!
| All times are GMT -6. The time now is 02:02 AM. |
