Windows Media HD
Is it a viable solution to use windows media encoder to capture from a dv camera using the "HD settings"? Especially if shot in anamorphic 16:9? Will this result in any high of quality video over just a regular DV stream?
No it will not. Neither will your computer be able to keep up.
DV is coming from the camera over the firewire port whether you want it or not. So if you are going to capture it in any other format then you are just converting from DV to something else. |
| All times are GMT -6. The time now is 11:46 PM. |
