-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Good 4:4:4 Video Capture Device? (https://www.dvinfo.net/forum/non-linear-editing-pc/23082-good-4-4-4-video-capture-device.html)
Peter Moore March 17th, 2004 03:04 PM
Does anyone know of a good video capture device that will capture 4:4:4 uncompressed, or near-lossless compression? I'm not talking DV. I want to get a real high quality capture from laserdisks. I can use my camera ADC to DV, but I don't think that will result in the highest quality image I can get. Also will it break my budget?
Peter
Don Donatello March 17th, 2004 10:33 PM
i don't think laser disc are 4:4:4 ... has to be some compression in there ... you might think more along 4:2:2 ...
http://www.blackmagic-design.com/index.htm
Martin Munthe March 18th, 2004 05:43 AM
Black Magic Designs only do 4:2:2 hardware with the DeckLink cards. For 4:4:4 this is the cheapest I can think of:
http://www4.discreet.com/lustre/
Peter Moore March 18th, 2004 07:26 AM
Interesting about LDs being only 4:2:2. I need to double check that but if that's true, then there you go.
What's DV?
Thanks a lot for the suggestions!
Ben Gurvich March 18th, 2004 07:43 AM
laserdiscs are analog,
Rob Lohman March 18th, 2004 07:45 AM
Peter,
DV NTSC is 4:1:1. DV PAL is 4:2:0
Peter Moore March 18th, 2004 07:45 AM
That doesn't mean the chroma is sampled at the same rate as the luma. Analog does not equal 4:4:4.
Julian Luttrell March 18th, 2004 11:29 AM
Does the Pinnacle Targa3000 capture 4:4:4? The product material goes on at some length about its 4:4:4:4 realtime capabilities...
Julian
Peter Moore March 18th, 2004 02:45 PM
Wow, these things really are going to break my budget! I guess I'm not going to get anything better than my GL2's ADC to DV.
Martin Munthe March 18th, 2004 06:09 PM
No the Targa is 4:2:2 hardware. The codec and software handling is 4:4:4. Targa and CineWave are the same thing. CineWave uses a 16-bit 4:4:4:4 codec if you want it to. That does not mean it captures 4:4:4 and outputs 4:4:4. And when it comes to digital video formats there are really only two devices that deliver 4:4:4 and that's HDCAM SR and D5.
Graeme Nattress March 18th, 2004 07:32 PM
If you're digitising from Laserdisc, I'd just dub to DV - it's not going to lower the quality for you because Laserdisc is not as good picture quality as DV.
Graeme
Rob Lohman March 19th, 2004 05:30 AM
I highly doubt your GL2 analog output to a 4:2:2 or 4:4:4 board
will increase your quality in any way.
Graeme Nattress March 19th, 2004 07:24 AM
No it won't and laserdisc does't warrant 4:4:4 (or even 4:2:2) because it doesn't have that level of colour bandwidth to start with!
Graeme
Peter Moore March 19th, 2004 07:46 AM
Yeah the question is whether laserdisc output warrants 4:4:4 and it sounds like the answer is unanimously no. Thanks all for the suggestions!
Akin Vincent March 19th, 2004 01:38 PM
Re: Good 4:4:4 Video Capture Device?
<<<-- Originally posted by Peter Moore : Does anyone know of a good video capture device that will capture 4:4:4 uncompressed, or near-lossless compression? I'm not talking DV. I want to get a real high quality capture from laserdisks. I can use my camera ADC to DV, but I don't think that will result in the highest quality image I can get. Also will it break my budget?
Peter -->>>
You don't need this kind of quality except you want to do some serious vertical layering with lots of graphics.
Secondly,laserdiscs don't give out 4.4.4 uncompressed video.It is like looking for that from a Hi-8 or superVHS signal.
Thirdly such cards are costly,check out www.bluefish444.com
