-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Clean cut (unwanted frame...) (https://www.dvinfo.net/forum/non-linear-editing-pc/21574-clean-cut-unwanted-frame.html)
Johnny Cheung February 18th, 2004 02:33 PM
My problem is that my mpeg1 looks fine when I see it on the computer, but when I made it a vcd and see it on the tv, I don't know why in some shots, the cut is not that clean, the next unwanted frame always appears at the end of the shot. I tried to check it on premire pro, but that unwanted frame is definitely not on the clip there...It is weird...
Does anyone know why?
Rob Lohman February 18th, 2004 04:13 PM
Sounds like something had gone wrong with interlacing. BUT,
the low resolution of a VCD should not have interlacing at all.
Could be your player is messing up? Can you try it on another
DVD player?
Glenn Chan February 18th, 2004 07:13 PM
It could be the way the VCD is encoded.
Johnny Cheung February 19th, 2004 03:42 AM
It actually looks the same on several players..
So i guess it is the VCd itself but not the player....do you mean if it is mpeg1 format, it shouldn't be about interlacing?
Rob Lohman February 19th, 2004 06:20 AM
That is correct. MPEG1 VCD is running at a low resolution 320x240
and thus only has one field to play with. And without the second
field you cannot have an interlacing problem solong as your
DVD player is not messing things up.
Julian Luttrell February 19th, 2004 07:39 AM
This _may_ result from your cut not coinciding with an I-frame in the resulting mpeg file.
Try changing your edit so the cut coincides with an i-frame exactly (the frame after the cut should be an I-frame).
With (say) an MPEG-encoding GOP of IBBPBBPBBPBBPBB (for example) you should make the cuts occur before frames 0, 15, 30, etc.
I am winging it a bit here because I have not myself seen the effect you describe.
Regards,
Julian
