-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   How to connect a camera to four computers simultaneously via firewire (https://www.dvinfo.net/forum/non-linear-editing-pc/19857-how-connect-camera-four-computers-simultaneously-via-firewire.html)
Lambis Stratoudakis January 15th, 2004 10:13 AM
Hi
At work we have 4 editing station 2 PC's(Avid Xress DV) and 2 Apple (Final cut Pro)
What we like to do ist to connect via firewire all the 4 Stations to
a Mini DV Player Recorder.
Is there any hardware (hub maybe) that can connect 4 Computers via firewire to one Mini DV Player Recorder / Camera??
Regards
lambis
Jonathan Stanley January 15th, 2004 11:12 AM
Yes there is a firewire hub that I have seen at Markertek. You hook up all 4 comps to the hub, and simply press a button to choose which IEEE route you want. It was rack mountable, but also a bit pricey in my opinion. B&H also has some, just go to their webpage and type in "firewire switcher" in the search box.
Lambis Stratoudakis January 15th, 2004 12:53 PM
Thanks Jonathan.
They are a bit pricey. I was thinking more something like this:
http://catalog.belkin.com/IWCatProdu...uct_Id=100300#
But I ask me if a Firewire Hub is what I need.
Jonathan Stanley January 15th, 2004 02:25 PM
No, the hub you have listed would be if you had 4 firewire devices that you wanted to connect to ONE computer. Your problem is the opposite. I believe you have to have a switcher, not a hub, for what you are asking for.
Hope that helps.
Lambis Stratoudakis January 15th, 2004 04:01 PM
I understand now.
Thanks very much Jonathan .
The only want I need is to find a cheap one firewire switcher.
Lambis
