-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Exposure in Post Production (https://www.dvinfo.net/forum/non-linear-editing-pc/18527-exposure-post-production.html)
Mike Lugton December 18th, 2003 12:50 PM
Just finished shooting a Holiday Pagaent for School and that some of the footage was low light, therefore giving me a lot of darker images than I would like. What recomendations could anyone give me in regards to altering it in Premiere 6.5 and Matrox RTX Extreme?? Have found when I adjusted increased exposure in post the footage becomes very grainy. Any thoughts or advice for a complete novice??
John Britt December 18th, 2003 01:34 PM
Hmmm... maybe try Levels in Premiere -- it gives you a little more control over the image than Brightness/Contrast (which I assume you were using before?). If you are familiar with Photoshop, the Levels function in Premiere works similarly.
You don't have a friend with After Effects, do you?
Mike Lugton December 18th, 2003 02:12 PM
John,
Thanks for quick reply. What exact function or effect do you mean in premiere? I do not have access to aftereffect....any specific effect in premiere you would reccomend?
Thanks again
John Britt December 18th, 2003 02:15 PM
Uh, like I said...it's called "Levels." It's with the video effects in Premiere 6.5
Mike Lugton December 18th, 2003 02:17 PM
thanks ...will try it tonight when i am home.....
Debu Gohain December 18th, 2003 02:37 PM
Mike,
With RTX100 do you have Matrox Real time plugins installed ???
If yes, you can use Matrox Colorisation... it will give control over Brightness/Contrast/ Hue/ saturation/ Lum/Black level/ Y/RY/BY
I think that will solve your problem.
___________
Debu
Studio Brahmaputra
Assam
Mike Lugton December 19th, 2003 08:26 AM
thanks debu, i will try tonight....thanks to all for your help.
Barry Gribble December 19th, 2003 09:08 AM
Mike,
I agree with John, you can do a great deal with Levels, though it can still turn a bit grainy no matter whay you do. Also in Premiere Pro, and I think in 6.5 but I'm not sure, there is an effect under "Image Control" called "Color Corrector". It is pretty complex, but you can do a lot with just a few of the controls in there.
Under the "HSL" setion they have (among other things):
Brightness
Contrast
Contrast Center
Gamma
These will all effect the image in the way you want. The key is using "Contrast Center". Usually if you have a dark video and you adjust the contrast, all the darks can run together. With Contrast Center you can say that you want the midpoint brightness to be somewhere in the dark area, and this will help you bring out detail in the dark areas. I reccomend this:
1. Add the Color Corrector Effect
2. Turn the Contrast almost all the way up (all Wihtes and Blacks)
3. Adjust the Contrast Center down until you have a good balance between the whites and blacks - i.e. you can make out the forms clearly
4. Roll the Contrast down to where you like it
I think this is a good way to bring detail out of the dark areas. It may sound a bit complex, but when you are moving the dials it will all make more sense.
Good Luck.
Barry
Mike Lugton December 19th, 2003 09:12 AM
THANKS BARRY.....BOY YOU GUYS ARE GOOD HERE!!!! I WILL LET YOU ALL KNOW ONCE I HAVE TACKLED IT WITH ALL YOUR SUGGESTIONS....THANKS AGAIN
