-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Your Impressions on Pinnacle Impression Pro (https://www.dvinfo.net/forum/non-linear-editing-pc/14135-your-impressions-pinnacle-impression-pro.html)
Peter Jefferson September 5th, 2003 05:18 AM
okies, just wondering what peoples thoughts are on this app.
Apparently it supports AC3 5.1 files, as well as multiple audio streams (ie commentary)
I was wondeirng what else it has on offer?
As im seriously considering a switch over from DVD Architect
Can i set an animation after a button is pressed? like some commercially available DVD's? Or does it just jump to the point where i want to go?
What about multiple files??
Can i only import 1 mp2 and 1 ac3, or can i have a series of mpg2's and ac3s and string them together?
Any thoughts or impressions (pardon the pun) would be greatly appreciated
Ed Smith September 5th, 2003 02:59 PM
Peter,
It might also be worth looking at the sonic range of authoring software.
Reel DVD - Motion menus, multiple audio and sub titles, MPG and AC-3 etc etc etc.
Producer - All the above with even more added features including animated buttons.
I use Reel DVD LE and it is a very nice product, and does most things I want to do.
www.sonic.com
All the best,
Ed
PS it might be good i a moderator moves this to the DVD/ Web forum.
Peter Jefferson September 6th, 2003 12:51 AM
thanx for the feedback, i tried reel dvd once.. but didnt have the patience for it im afraid...
as i do ALOT of dvd projects, i need somethign that i can easily pick up and do a full menu within half an hour.
Ill look into it again
reading thru the specs, it says it can convert to dolby, however i do not want to do this, as all i need to do is import a 5.1 Dolby Digital AC3 file, but i can see if this app supports it....
Any ideas?
thanx again!
Ed Smith September 6th, 2003 06:50 AM
It only mentions dolby digital stereo and other stereo formats on their website - However looking in the help file of Reel DVD LE it says it supports Dolby digital AC-3, 48KHz, stereo and 5.1 ch.
You are right that you need patiences, but I sat down with the demo to begin with for half a day and I managed to pick it up pretty quick.
What I like about it is that you can see where each menu, video or title are linked. Also becuase it has the same feel as Scenarist a very high level authoring tool, it will make it easier if I ever wish to upgrade that far.
Cheers,
Ed
Peter Byram September 10th, 2003 02:21 AM
Have a look at the shareware offering on www.mediachance.com called DVDLAB. I've found it straightforward to use with plenty of features. Unfortunately there is a bug that spoils it for PAL use at the moment.
Rob Lohman September 10th, 2003 03:28 AM
Keep in mind that not all program support everything. A lot of
programs support multiple audio & subtitle tracks. To my knowledge
only three support angles:
1. Impression-Pro (max 2 angles I believe)
2. SpruceUp DVD Meastro (no longer available)
3. Sonic Scenarist (high end expensive product)
Only scenarist comes with an AC3 encoder I believe. But if you've
got Vegas+DVD you already have an AC3 encoding availability
there.
Julian Luttrell September 10th, 2003 09:55 AM
Impression - beware!
I bought and TRIED to use Impression. Honestly, I tried and I tried! But it's shot through with bugs.
Oh, it's Pinnacle again isn't it? ;^)
Regards,
Julian
Jami Jokinen September 10th, 2003 11:33 PM
After trying to find a reasonably priced authoring program with multiple audio streams and subtitles I got Impression DVD pro.
Making menus and subtitles is not easy and requires external programs (e.g. Photoshop for menus). But the basic authoring, navigation etc. is quite easy and I haven't found any notorious bugs yet.
And I found a way to make the subtitle creation a lot easier. A few freeware programs helped with this.
If I would have had the money, I would have gone for Reel DVD. But I didn't. Impression works, but makes you work also.
