64 Bit HDV Machine
It's a little early but I figured that I'd start off 2009 with a new editing system/PC -
Getting close to finalizing the final build components and thought I gather some input and or opinions from the masses here at DVinfo at what I have so far - CPU: Intel Core 2 Quad Q9550 Newegg.com - Intel Core 2 Quad Q9550 Yorkfield 2.83GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor - Processors - Desktops Motherbird: Gigabyte GA-X86-DQ6 http://www.newegg.com/Product/Produc...82E16813128331 OS: Windows Vista Ultimate SP1 64 Bit Newegg.com - Microsoft Windows Vista Ultimate SP1 64-bit English 1pk DSP OEI DVD for System Builders - Operating Systems RAM: Geil Black Dragon 8GB (4 x 2GB) (As recommended by M/B manufacturer) http://www.newegg.com/Product/Produc...82E16820144074 HDD: Western Digital SATA 7200RPM 250GB (OS / Apps drive) Newegg.com - Western Digital Caviar SE16 WD2500AAKS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - Internal Hard Drives ROM Drive: LG Super Multi Blu-ray Burner 6X Newegg.com - LG Black 6X BD-R 2X BD-RE 16X DVD+R 6X Blu-ray DVD-ROM 4MB Cache SATA Internal Blu-ray Burner Super Multi Blu-ray Disc Burner & HD DVD-ROM Drive Model GGW-H20L - Blu-Ray Burners Case: Cooler Master HAF 932 (Full tower) Newegg.com - COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - Computer Cases Still researching the power supply and video card options. The final outcome will be for the transition from my use of Sony Vegas Pro 8c (32bit) to Adobe Production Premium CS4 (Vista 64 bit certified) http://www.adobe.com/products/creati...on/systemreqs/ |
Any specific reason for that mobo? It has two drawbacks IMO, the chipset and the SLI capability, which may give compatibility issues with the first and no advantage on the second. You don't want SLI on an editing machine.
I would call that a 2008 machine, certainly not 2009.
I would wait and build a Nehalam system or just get a refurb Quad core system ($500) for now if you need a system right away. I would also get an Intel X-25 SSD for the system and applications drive. It's far superior to a HDD and is probably the best performance upgrade you can do even though it's very expensive. |
Stability -
I'm slightly perplexed at your SLI comment though - Perhaps you can explain to me the drawback of having a mobo with SLI or XROSSFIRE capabilities. I'm open to any suggestion or recommendation you may have for another mobo with the exception of anything produced by ASUS. |
Well technically speaking you'd be correct as I'm looking to have it put together by the end of this year - therefore starting off with a new 64bit HDV in 2009 not for 2009. The specs on the Nehalem are impressive but I'm not really seeing the need to become an early adopter at this point. I can get a more than decent system now and hold out for the successor to Nehalem which I believe will be Sandy Bridge/Ivy Bridge |
I just built a new rig with the Q9550 and Vista 64. Blazing fast combo. I didn't care about teetering on the bleeding edge of technology; I just wanted something NOW and STABLE and USEFUL for years to come.
I think the Q9550 is overclockable, but I'm leaving it alone. Plenty fast for me in stock condition. What about a CPU cooler? I'm running a Arctic Pro 7. With all 4 cores at 100% during a render, the Q9550 is at 40*C. Nice. Consider a 10K Raptor OS/program HDD; it will make your system sing. Vegas 8.1 loads in about 2-2.5 seconds. Nice. $0.02, Steve |
The videocard is hardly ever used to its full capability, certainly not for NLE. If you are heavy into 3D modelling that is another story, but for regular Vegas/Edius/Adobe editing, including After Effects, Boris Continuum etc. almost any decent videocard like an ATI 4650 is more than sufficient. Anything more is just a waste of money and will not give you any noticeable improvement. I agree with the SSD suggestion for OS/programs. I suggest that you invest in a good raid controller for your media drives and get at least 4 internals for your media and projects. |
Thanks for the input -
I'll do some looking around and post the revision[s] later on. SSD [especially the one recommended earlier] will push me over budget this time around. I wasn't looking to pick up anything super spectacular in regards to a videocard either - something 'middle of the road' will suffice. |
Laurence
If your really want the Q9550 check it out - this weekend $279.99 / ship / tax FRYS.com*|*Intel good luck |
- made some revisions -
Laurence:
You didn't say exactly what you will be editing on your new machine. If it were to be AVCHD, the Q5550 or Q9650 based machines are a little too slow. DV or HDV are no problem. |
The primary media sources will be DV and HDV with most of the focus on DV until Blu-ray become more common. |
