-   Non-Linear Editing on the PC (https://www.dvinfo.net/forum/non-linear-editing-pc/)
-   -   Fat 32 to NTFS on XP (https://www.dvinfo.net/forum/non-linear-editing-pc/13152-fat-32-ntfs-xp.html)
Dale C. Elliott August 12th, 2003 08:01 AM
Hi all,
I need to know how I can change my file format from Fat 32 to NTFS on my windows XP Pro? I just finished checking the archives, and it is mentioned but it is not explained. Can I do this without reformatting my drives.
Dale
Adrian Douglas August 12th, 2003 08:50 AM
Yeah, you won't have to reformat it's a non-destructive conversion. To do it type "convert drive letter: /fs:ntfs" without the quotes into the 'Run' input box or at the command prompt. Make sure you back up important files before you modify any system files or file system .
Edward Troxel August 12th, 2003 09:09 AM
Alternately (but it costs), a program such as Partition Magic can also perform this task. While Partition Magic has more bells and whistles (not to mention a graphical interface) and can also perform additional tasks, "convert" should work just fine.
NOTE: You should back up the drive BEFORE converting (just in case).
Dale C. Elliott August 12th, 2003 09:48 AM
Thanks for your replys,. Yes I was planning on backing up the drives. Here's a stupid question. Where do I find the "run" input box?
Dale
Adrian Douglas August 12th, 2003 09:51 AM
Click on the "START" button and you should find and icon with "Run" next to it.
When you carry out the conversion XP will tell you that it cannot perform the conversion at this time and will schedule it to be done at the next time you start you r computer. This is normal and you should select OK.
Dale C. Elliott August 12th, 2003 10:05 AM
I thought it was that one, but wasn't sure if it was something else. Its been a long day, and I am only half though it.
Thanks Adrian,
Dale
Dale C. Elliott August 12th, 2003 01:53 PM
Adrian,
I gave it a try, and all I got was a flash of a window and that's it. Nothing else happened. Any ideas?
Dale
Imran Zaidi August 12th, 2003 02:49 PM
Dale, it would be best if you followed the directions from the horse's mouth:
http://www.microsoft.com/windowsxp/p...convertfat.asp
The section named "Converting to NTFS Using Convert.exe" should have the exact steps spelled out.
Dale C. Elliott August 12th, 2003 05:01 PM
Thanks Imran,
Yep, that would do it, I should have check there first.
Dale
Adi Head October 27th, 2003 04:22 PM
how do check to see if a drive is fat, fat32, or ntfs?
John Loretz October 27th, 2003 06:01 PM
On Windows XP, you can on my computer, then highlight the drive, then right click on properties. It should tell you if the file system is Fat32 or NTFS.
Cheers,
John
Adi Head October 27th, 2003 07:22 PM
thanks john.
i've heard two different opinions on the ntfs vs. fat32 issue.
one says that with windows xp you should make all your drives ntfs because windows xp is built for working with ntfs. the other says that the ideal set up for a video editing computer is to keep your system drive fat32 and make the drive where you store your video files ntfs. i don't remember the details and reasons for each argument and i definately didn't understand them. i'm not much of a computer genius. any thoughts?
Will Fastie October 28th, 2003 07:29 AM
NTFS is the better way to go on all drives.
There two exceptions. One involves some recovery techniques that require the system drive (usually C:) to be formatted as FAT. As time has passed, this has become less critical; at this point, I would not give that one much weight. The other is the case where the system is set up to boot multiple operating systems, such as XP and Windows 98, from the same drive. Win98 requires FAT.
If your system is only running XP, just use NTFS.
Adi Head October 28th, 2003 08:48 AM
thanks.
Rob Lohman November 11th, 2003 03:01 PM
The other reasons was overhead with things like security, but
that isn't that important anymore. NTFS gives you a lot of extra
things, like the following:
1. smaller cluster sizes for larger harddisk
this results in less wasted space
2. journeling file system
this system keeps a log of what is being changed and to
what files. So if your system would crash at the instant NTFS
can revert the file back to either BEFORE the change was
made or check if the change was made correctly. Thus
resulting in less corrupted files when a crash happens
(which might be as easy as power failing)
3. larger files
files can be larger than 4 gigabytes
Then there are some extra things mostly related to security...
