Quad Core - ohh, JOY! Q9450@3.4ghz
Hi,
Just upgraded my system from: AMD Athlon 64 X2(dual core) 4600+ with 4gb mem Vista 64 to Intel Q9450 Quadcore, overclocked to 3.4ghz(from 2.66) 8gb mem Vista 64 I made some speed tests. I captured 1 minute of Video in DV-AVI and the same video as HDV1080i@25(canon hv20). Started new project in Prem Pro CS3 - used Adobe Media Encoder to render MPEG2-PAL-DVD HQ Widerscreen. Are you ready for the results? AMD machine ------------- DV-AVI -> MPEG2PALDVD 58 seconds HDV1080i -> MEPG2PALDVD 276 seconds Intel Quad: ----------- DV-AVI -> MPEG2PALDVD 19 seconds HDV1080i -> MPEG2PALDVD 63 seconds We're talking 430% more power! So go get a Quad, you're worth it! My new rig: ------------ Gigabyte DQ6 DDR2 X48 Express Q9450@3.4ghz 8 gb OCZ PC8000 memory Geforce 8800 GTS 512 G92 No down side? Alas, some programs are singlethreaded and thus won't benefit much. The Q9450 supports SSE4 and have 12mb cache - so even single-minded apps gets a boost! Why are you still reading - you should be ordering a new CPU :-) Regards, LlllAaaaRrrrSsss (quad version) |
So many "reads" and no reply :-)
I can add a short list of single-minded apps(so far): DivX - you can enable multithreading - but I only get about 30% on all cores including DivX converter and DivXAuthor // Lz |
Dear Lars,
Nice info, thanks for posting your results. Is your system stable running at 3.4Ghz? Have you performed a long render, long enough so that the cpu gets a real workout? I ask just in case the cpu gets too hot. |
Dan,
Thanks! I've run an eight hour burn-in-stress from SiSoftSandra, 100% cpu usage. I have a Noctua CPU cooler and the Antec P182 case has 2 120mm fans surrounding the CPU - so the computer is very quiet AND cold! I belive I could get the machine running 3.6 stable - but I won't push my luck! The Q9450 is VERY clockable :-) // Lazze |
I went from a single 3.2 intel core to a q6600 quad recently and sure, it renders faster but that is not really what matters most to me. My old system did struggle a bit if I opened Premiere/encore and Photoshop simultaneously and everything got somewhat sluggish. That's not the case anymore now, but beside that my quad doesn't help me edit faster :)
I'm actually most happy if my system is stable rather then saving half an hour on rendering a wedding. Since I take a break every 2 hours at least from editing I usually plan my work that my machine renders during that time. I upgrade my pc every 3 years and never go for the fastest combination as this is a waist of money, buy high end today and already have a mid end system 4 months later. |
Noa,
True true! But today the Q9450 is "mid-end" - here in sweden it has the same price as Q6600. But Q6600 doesn't have SSE4 and is still 65nm technology(draws more power and generates more heat). For me, rendering times are important, because with fast renders I can test 4-5 renders per "short movie" and get the best Quality vs Size. It also gives me a much faster workflow in some situations (like capturing 60min, edit 15min, generate DVD 15min, means I can go from rough DV tape to a "nice" DVD in less than 2 hours). // Lazze |
Hi Lars,
Great thread. I'm and currently in the process of building a brand new edit suite. $2000. I also want to run Quad with 8gb of ram pc6400... Just a question. Do you have any other hardware tips for making a superfast suite??? What made you choose that motherboard? Did you find the better graphics card improves editing or not? cheers |
Blake,
I'd decided to go with the X48 chipset - and then there aren't so many choices. The Gigabyte DQ series of motherboards are famous overclocking/stable boards. I didn't want to go DDR3 - so the Gigabyte DQ 6 X48 DDR2 was perfect for me. The gfx-card doesn't real speed up editing - but its good for games :-) Quad core is really nice - gives you a very quick and responsive OS + great rendering times. Good luck! // Lazze |
Double Xeon vs Quadcore
I am building a new editsuite for HD right now (running CS3 and to be added with cineform Prospect HD)
Motherboard: Supermicro X7DWA-N Case: Supermicro, 7045A-WTB Processors: two 5430's RAM: Will put 8GB to start with HDD: 4x internal SAS Hitachi's, 320GBs I believe this is a good alternative to the mentioned quad cores? The 5430 is about 350Euro at the moment... What would you expect in case of speed compared to the conducted tests ? I hope my new system will be even faster - and unfortunately also more expensive...:-(( Ulli |
Ulli,
Your machine will probably be faster - and as you say, alot more expensive. My machine costed 1350 EURO complete(without monitor). // Lazze |
Cost comparison
Yeah - there is the price tag for the Server type of machine... will be roughly double in price.
But thanks for the comparison of dual core to quad core using CS3 - may be I should change my dual core to quad core on the current machine as well... Ulli |
Speed test with my old Pentium D 2,8 Ghz on a Asus P5LD motherbord
just made a short test with my old Pentium D 2,8 Ghz machine (2Gb RAM, XP professional SP2, CS3) exactly 1 min on the CS3 timeline with audio HDV1080i -> MEPG2PALDVD 247 seconds So a little faster than the AMD machine, but probably worthwhile to upgrade to quad core as well... Ulli |
If I were you, I'd go for a Q9450 - save the money and upgrade one more time in 18 months. The top-of-the-line stuff almost never keep its value for more than 8 months...
Anyhow, good luck! // Lazze |
Just got my Quad 3 weeks ago. 1.5TB drive space, 4GB DDR2, RARRRRRRR
It is a rendering beast!!! Love the quad... |
I'm looking to upgrade my editing machine: A P4 3.2ghz HT ... Think I should see an improvement?
