Matrox RT.x2 witch computer should i buy?
Hello all,
I want to build a editing station with the Matrox RT.X2 , what specifications should i put in my computer that will synchronized with this card? i want a strong system and a fast one. can you tell which parts should i order? (board, memory, video card, cpu) thanks in advance |
I think you might have better luck asking this question in Matrox RTX2 user forum
http://forum.matrox.com/rtx2/viewforum.php?f=2 |
Yes, either that or the Matrox site with the system recommendations. Use that for the base components such as motherboard and GPU, but the ram, stick with a good name and the same for a case and power supply. The thing beware of is you need a longer case as the card is full length.
For mine, it cruises well with Abit 965P motherboard, Q6600, 4GB ram. But you really need to spec it out yourself for your needs. |
