-   Nexto DI Mobile Storage Solutions (https://www.dvinfo.net/forum/nexto-di-mobile-storage-solutions/)
-   -   Nexto 2500 not recognising MxR Cards (https://www.dvinfo.net/forum/nexto-di-mobile-storage-solutions/478745-nexto-2500-not-recognising-mxr-cards.html)
Bruce Rawlings May 15th, 2010 03:54 AM
Have just taken delivery of a Nexto 2500. It copies SxS cards rapidly but sees MxR with good Transcend 16gb(2008) cards as unrecognised media. It reads the SDHC card when removed from the adaptor and placed in unit SDHC slot. BTW I can see this unit will solve backup storage brilliantly when having to travel light.
Thierry Humeau May 15th, 2010 07:24 AM
This is normal. The interface protocol used by the MxR is different from the one used by SxS cards. You need to take your SD card out in order to read it in the NVS2500. Same applies to a PC with Express Card slot, it wont read a SD card in a MxR adaptor.
Bruce Rawlings May 15th, 2010 07:35 AM
Thanks, to confirm the Nexto has no problems copying the SDHC card recorded in the MxR when using SDHC slot.
Anthony McErlean September 24th, 2010 06:59 AM
Does the same thing apply to the MxML adaptors, the NVS2500 doesn't recognise them?
Alister Chapman September 29th, 2010 12:13 PM
Yes, same thing applies. The express card slot has two types of internal connection, PCI express and USB. On the NextoDI the PCI express interface is used for SxS type cards as opposed to the USB type connection that the MxR, MxM, Hoodman and even the Sony adapters use. The PCI express interface is what gives the NextoDI its high speed transfer ability.
Larry Seong April 25th, 2011 06:24 AM
Re: Nexto 2500 not recognising MxR Cards
NextoDI shall release new firmware before May for NVS2500.
This firmware supports SxS adapter which is using USB portion of ExpressCard I/F.
This includes
1) SDHC to SxS adapter from SONY
2) MxR and simmilar adapter
The Wise SxS card has compatibility issue at this moment.
This USB based memory card behave very strange during file copy and makes error.
We'll try to solve this compatibility issue at later firmware release.
Larry
