-   NewBlueFX plug-ins (https://www.dvinfo.net/forum/newbluefx-plug-ins/)
-   -   Anyone Try NewBlue Titler with 32-bit Color Processing? (https://www.dvinfo.net/forum/newbluefx-plug-ins/502381-anyone-try-newblue-titler-32-bit-color-processing.html)
Steven Reid November 6th, 2011 07:06 AM
SOLVED: Anyone Try NewBlue Titler with 32-bit Color Processing?
2 Attachment(s)
I tried this on the Sony forum with no response, so maybe I stand alone with my problem. In Vegas 11.0 x64, blank timeline, 8-bit color processing, when I apply the NB titler to an empty event or generated media event, everything works normally.
When I switch to 32-bit color processing, the text in the preview window and the rendered text disappears into a garbled line of pixels at the bottom of the screen. See my screenshots below to contrast these two attempts.
Can someone else try this? Am I missing something here? BTW, I can nest an 8-bit color project with NB titler into my 32-bit color project and have it look normal.
Steve
Edward Troxel November 6th, 2011 07:34 AM
Re: Anyone Try NewBlue Titler with 32-bit Color Processing?
(Full Range) worked fine on my system. I changed it to the middle entry (Video Levels) and the text in the Titler GUI disappeared a couple of times but the Vegas preview still looked fine. For more help, you need to start a help ticket at NewBlueFX | Video plugins and audio effects for Avid Liquid, Avid Media Composer, Adobe Premiere, Adobe After Effects, Apple Final Cut Pro, Apple Motion, Corel VideoStudio, Pinnacle Studio, Sony Vegas, Canopus Edius and other video editors - NewBlueF.
Steven Reid November 6th, 2011 07:43 AM
Thanks for the quick reply, Edward! I suspect something about my system specs is at fault since this worked for you. I love the Titler! I'll file a ticket as you suggest.
Steve
Adam Stanislav November 6th, 2011 12:30 PM
Actually, it is the same on my system. But only if using the titler as a Video FX, not when using it as a Media Generator.
Steven Reid November 6th, 2011 12:59 PM
OK, thanks. NB Titler as a media generator in all color bit depths worked for me, too. I didn't read the manual, to the extent that one exists. I just jumped right in. Is this the trick: apply only as a media generator, not VFX? I have no problem with that.
Steve
Edward Troxel November 6th, 2011 02:23 PM
My test was as a media generator - I did not test as an FX. I just tried it and can confirm I see the same results as an FX.
Steven Reid November 6th, 2011 02:46 PM
Well, dang, Edward, I guess something is wrong after all on my end...and Adam's, too!
At least I have two workarounds now, which I guess is a credit to Vegas by allowing us to skin a cat several ways. Hrmmm. I guess I can troubleshoot directly with NB.
Steve
Edward Troxel November 6th, 2011 05:25 PM
I'm saying that when I added it as an FX, I see the same issue you are seeing and I've reported it to the developers.
Steven Reid November 6th, 2011 05:36 PM
Roger that, Edward. ;)
Richard Crowley December 26th, 2011 09:42 PM
Meh, the NewBlue titler is usable (and certainly better than the very primitive native title generator), but I am very disappointed how primitive these are compared to the built-in functionality of the Adobe Premier title generator. I suppose I will have to get used to using external apps to generate titles. :-(
And even the latest build of Vegas 11 seems just as buggy and crash-prone as 9.0 was. Almost considering dumping Sony and going back to Adobe. There are a few things that are nicer with Vegas, but not enough to make up for what I used all the time in Premiere (and I was using Premiere Pro 1.5!)
