Does FVD-C1 cable adapter fit VPC-HD1?
Does an FVD-C1 cable adapter fit the VPC-HD1? The cable adapter is, of course, the small piece that lets you power and charge one of these Sanyo camcorders without a dock. If I can get assurance that the FVD-C1 cable adapter fits the VPC-HD1, then I have good reason to believe that my FVD-C1 adapter/charger will power and charge the VPC-HD1.
If not, I will have to buy a VAR-G9 adapter (expensive) or a VAR-L40 charger (awkward because it requires removal of the battery from the camcorder). |
The HD1 charger outputs 5v DC 2.0A tip is positive.
What happend to your charger.. (ya know the one which came in the box)..? Bo www.bophoto.com/HDV |
I won this auction:
As you can see, this item doesn't come with accessories. :( |
Good for you.!
Its a very generic cable plug... but there is a catch, you need a little rectangular adaptor to connect to the bottom of the camera. without that there is no way of plugging the power straight into the camera. Short of that piece I would say get the external charger which you can pop the battery into. Or maybe even easier.. call Sanyo and tell them you lost your charging adaptor, I would guess its a $20 piece. I was almost going to say you could purchase my deskstand but then realized it might be nice to have when I sell the camera sometimes in the future. ha ha. Bo www.bophoto.com/HDV |
Lawrence,
He He. THAT is the big question... I can send you a picture of mine tonight and maybe that will answer your questions. But I can not say for sure.. maybe somebody else can. Don't forget Sanyo, their tech-support knows for sure.! Bo www.bophoto.com/HDV |
Well, indications at the moment are good.
1) The DB-L40 battery has already arrived. Although it's longer than the DB-L20 that the FVD-C1 uses, it is able to charge in the FVD-C1's charger as long as a rubber band holds it in. So the battery is charging as we speak! 2) I borrowed a VPC-C6, and it does fit the FVD-C1's rectangular adaptor. That's a good sign that perhaps the VPC-HD1 will also fit that same adaptor. |
