Uses for your Monopod
I'm considering purchasing an inexpensive monopod for my amatuer work. I shoot mostly handheld and sometimes with a tripod. I would use the monopod mainly for my daughter's sports. Would you recommend a monopod for this work for steadying the shot? I'm looking at the the Bogen 676B monopod and 3229 head. I like that the 676B is very short collapsed and light which might encourage me to use it more frequently. My camera is the Sony HC7.
Are there some that prefer handheld over a using a monopod? Thanks. Dave |
Mono pod
A mono pod is a great choice for that size camera. The problem with some of the real small cameras these days is they make a great picture, but because they are so small, you can't put them on you shoulder like the big camcorders, which in the hands of a good cameraman, was a pretty good steady platform for handheld work. The mono pod really lowers the center of gravity for the camera and eliminates some of the hand wrist movement that always comes when tryig to handhold the smaller cams. I'm not sure you need any kind of pan'tilt head for the mono pod however. For any kind of pans or tilts, I think you are much better off with a tripod.
Hi David,
You don't mention what "sports" your daughter is into, that could make a difference in what folks suggest. As for the Mono-Pod, you can increase it's steadiness by attaching a small handle to it and using a Neck Strap attached to the top. You can also use a holder that attaches to your belt, to allow for more mobility. I've also added a custom articulating head to it, allowing the Cam to be at different angles. These are the Mods I've made to my Bogen unit. Another option is a Chest-Pod unit. I've Modified mine to include side handles for maximum control. For strickly handheld, I've made up a handle for the Cam to allow for better control of it. Can send you Pics of these units and Mods if interested. Harold |
Thanks guys. I didn't know the monopod could also be used for lowering the center of gravity for a handheld shot. Great info.
I'm probably going to order the monopod and head and give it a try. |
Carrying the monopod along questionable streets might also make you an unlikely target for mischief. I know I have carried mine like a walking stick when the neighborhood was in doubt.
I purchased the Manfrotto 676B Monopod and 3229 head. Both products are a very nice quality given the low prices. Other than testing it once, I haven't had a need for it yet.
Playing around with my monopod, I found another little trick: I hold it upside-down, with the camera 6 inches off of the ground. Afterwards, using my NLE, I invert the image so it's upright. This allows for a cheap low-mode camera shot.
