-   Micro / POV Camera Systems (https://www.dvinfo.net/forum/micro-pov-camera-systems/)
-   -   HDR-AS100V POV Action Cam - card information needed (https://www.dvinfo.net/forum/micro-pov-camera-systems/523208-hdr-as100v-pov-action-cam-card-information-needed.html)
John McCully May 18th, 2014 02:56 PM
Re: HDR-AS100V POV Action Cam - card information needed
Good point Ron. Certainly in my case with the Kingston I just popped it in and away we went (after I turned it around the right way).
Matt Sharp May 18th, 2014 08:58 PM
Originally Posted by Ron Evans (Post 1845657)
Did you format the cards in the camera ?
Yes, I formatted in camera before and after formatting to exFAT on the computer. Formatting in camera didn't change the card format to exFAT so that's why I did it on a computer (OSX if you're wondering). According to B&H XAVC-S recording requires SDXC cards, so that's what I'll try next.
Originally Posted by John McCully (Post 1845656)
Matt, I am quite surprised that the Sony 32GB microSDHC Class 10 UHS-1 Memory Card with microSD Adapter didn't work. The card that did work for me is also a class 10 UHS-1 I believe but is 64 GB.
Do you have a link to the card that worked for you?
John McCully May 18th, 2014 10:39 PM
1 Attachment(s)
Better than that: here's a photocopy of the container the card came in.
Ian Newland May 19th, 2014 01:15 AM
Did you format the cards in the camera ? I know I had to do this for the GoPro even though I had formatted to exFAT in the PC.
Ron Evans
The GoPro formats it's own little modified exFat version to the card, that's why a computer exFat format will not work correctly and why you should not then cross use it in other devices.
Ron Evans May 19th, 2014 05:31 AM
Yes I know, that is why I wondered if the Sony needed to format in camera when set to XAVC-S too. It is always good to let the cameras format as they often place directories during the format for data base recovery etc.
Ron Evans
