GoPro HERO2 Mounting Question
Hey guys,
I recently bought a HERO2. I lot this camera. One issue I'm having is with the mounts that you stick to things. I have one stuck to my motorcycle helmet but it allows the camera to shake. It's not a lot of movement, but it definitely moves. I stuck another one on the bumper of my car and it shakes too. I've created little plastic shims to remove this, but I was wondering if anyone has experienced this and if there is a fix for it? Thanks! Charlie Durand Mountain View, CA |
Re: GoPro HERO2 Mounting Question
Charlie:
Are you sure the camera is physically moving? Because at some vibration levels, the CMOS sensor "jelly cam" issue can be very noticeable. It's more of a swimming motion in the video, rather than an up and down shake. |
Yes, it is moving. I get the jelly-like effect as well.
If I use my homemade shims the shaking almost entirely goes away and the jelly effect rarely happens unless the wind speed is really high (80+ mph). |
Are you using the little vibration plug the camera comes with?
What is the vibration plug?
It seems my HERO2 (Motorsports Package) didn't come with the anti-vibration plug.
You can buy one with the "Grab Bag of Mounts" but I don't really needs all that stuff. I don't see a way to order just the anti-vibration plug. I sent an email to GoPro asking if there was a way to order just the anti-vibration plugs but they have yet to respond. I also asked if my unit should have come with one or not. I can't determine that for sure either. |
It should have come with one mine did
