Capturing 1080p in the wild for 12+ hours
I've a couple of tiny GoPro HD cameras which will be placed close to protected species next year (have the relevant licences) and the new firmware update now gives the ability to output live 1080p.
This opens the door to recording for many more hours than the SD cards can manage, but onto what? Given that these cameras need to output their footage for at least 12hrs is there anything out there that can record HD and will run off 12v batteries? Your thoughts are awaited with great interest. Chris |
What do they output? YUV HD
The output is to the onboard card is Mpeg4 file(s) containing PAL compatible footage.
The live feed however is 1080p TV footage so the Pal output will be YUV. |
hi
As far as I can see there is only a composite output from the camera. Then you will not have 1080P recorded on external recorder - you can only record HD on the internal card. I am not aware of the TVsignal on the compositecable. Guess it will be a NTSC signal at 60hz and not pal as it is 50hz and the camera cannot record at that framerate. |
Hi Bob
Thanks for your thoughts. The camera is switchable between NTC and Pal so thats not a problem but I do note that the composite output rather messes up my idea. May have to invest in 64gb sd cards, if supported in a later update, and provided external power, as that would then give 8hrs on 1080p. Spring is a long way off yet so I'll put more thought to this. Many thanks |
Hi
I am using the sony HDR-SR7 to record during the night. It has nightvision and onboard harddisk that can record for max 22 hours. 12V powersupply can be supplied. HDMI out makes it possible to record in HD on an extern device if nedded. |
Battery life will be an issue. The longest I've had my HD Hero running is 6 hrs doing a time lapse, so external power will be needed. |
Great then. Mine only have a composite cable unless you can use the same cable for HD out?. Analog YUV HD you can convert to HDMI or HDSDI and then you can record to a nanoflash recorder. First converted there are several posibilities for recorders running 12V.
Cannot remember any smal YUV HD recorders. |
I think you might have a different model from the current HD Hero. My HD Hero has 3 plugs on the one side, Composite out, USB and then a HDTV out (YUV).
Found the HD cable - and yes my HD hero can output HD. The great thing about my HD hero camera is that it could be put somewhere where it could resist water and fog but it cannot when DC and Video out is mounted.
