-   The Long Black Line (https://www.dvinfo.net/forum/long-black-line/)
-   -   Head cleaners and tapes (https://www.dvinfo.net/forum/long-black-line/9041-head-cleaners-tapes.html)
R.J. Paradee April 27th, 2003 12:32 PM
I tried the search first, but couldn't find my answer, so here goes:
My Gl2 is only a couple of months old, from reading this forum, I now know it's not advisable to switch tape . I started with fuji, (used about 6 tapes) then switched to Maxell (used another 6 tapes) Now that I know Fuji is the best, is it to late to switch back? Or is Maxell a great tape and I should just stay with it?
I got a good deal on a case of maxells. But I don't mind eating it.
Secondly, Do video heads become magnetized? Is that why we're suppose to clean the heads with a dry tape cleaner every 20 or so hours? Some people say the head gets scratched everytime you use the head cleaner. I don't want to keep scratching it. How about using a high professional grade wet solvent and carefully clean them that way. Similar like I do to my audio gear. Do you have to use the dry head cleaner? I really believe in properly maintaining my gear, I'm not trying to get out of running the head cleaner, just looking for some advise.
Jeff Donald April 27th, 2003 12:50 PM
I don't know of any mini DV wetting cleaning tapes (systems?). Manufactures recommend dry cleaning, it's generally thought to be safer. People had a habit of using too much liquid and causing damage from excessive liquid.
Your heads are getting worn (scratched as you would say) every time you record, playback, rewind, fast forward etc. The use of a dry cleaning tape when used according to the camera manufactures and cleaning tape instructions are very safe. They will not cause excessive wear unless used excessively.. The key is to follow the directions.
Modern video heads do not become magnetized. Tape head demagnetizers are not recommended for mini DV cameras.
If you are having no problems with the Maxell tapes, I see no reason to switch. At the very least I see no reason to waste a box of tapes. Finish the box, run a head cleaner according to the directions and switch. If you're really worried, have the whole tape path and video heads cleaned professionally by Canon. Continued use of the Maxell's will not harm your heads.
K. Forman April 27th, 2003 12:59 PM
What Jeff said, is very much what is recommended. However, I have also heard that "occassionaly" switching tape brands isn't too bad, if you use your head cleaner before and after. The problem with switching tapes, is due to different types of lubricants used. This will gum up your mechanisms.
R.J. Paradee April 27th, 2003 01:00 PM
tapes and head cleaners
Thanks Jeff! Just what I needed to hear. I'll go thru this box, clean the heads and switch to fuji. Does anal-retentive have a hyphen? I love my new Gl2 so much, I just want to give it the tender luvin care it deserves...
R.J. Paradee April 27th, 2003 01:03 PM
Thanks Keith. You guys are great! It was the lubricants I was concerned about. I'm good to go!
Frank Granovski April 27th, 2003 05:36 PM
Here's some tape info plus further tape links:
http://www.dvfreak.com/tape.htm
R.J. Paradee April 27th, 2003 06:29 PM
Thanks Frank, Great article. Much Appreciated.
