Dual MiniDV Deck wanted - but which one?
Hi I have come into a situation whereby I need a deck that can playback 2 different mini dv tapes at the same time through composite out. If the deck also had a firewire connection for capturing this would be helpful, but I'm not looking to spend too much. If anyone has any suggestions they would be greatly appreciated.
David |
Are you saying one deck with 2 dv tape drives? Never seen that.
ash =o) |
Neither have I. Panasonic and JVC offer some dual decks, but they're S-VHS and Mini DV, or DVD and Mini DV. I've never seen one that has two Mini DV transports.
ive seen single decks for £700 or less. I know you can get dual decks as I used them at uni.. wish I'd taken note of the model numbers.
Basically I need to be able to play 2 different mini dv tapes and select which one I want to be outputted to a big screen through a vision mixer. I suppose this coul dbe done with 1 deck and switching tapes but would be more practical with a dual tape one.. if they exist!! |
AFAIK, they do not exist... just get 2 decks and a switcher.
ash =o) |
The only Dual DV deck I'm aware of is the Panasonic edit laptop. Will cost you a lot of dough though... ;-)
http://www.globalmediapro.com/video/...r_PAL--52.html |
that's dvcpro, not mini dv. Have never heard of a dual mini dv player.
I wont waste the time on saying theres no such thing. But there is a Panasonic DVC Pro dual deck...the AJ-LT95E this is not discontinued to my knowledge. But with this particular deck you would us the adapter AJ-CS455 which is basically converting the dvc to mini dv. That is the only possible solution I can think of.
Aha, did not know that. Thought it was a complete different sort of tape.
| All times are GMT -6. The time now is 04:22 AM. |
