-   The Long Black Line (https://www.dvinfo.net/forum/long-black-line/)
-   -   Synchro-edit Control Mystery Solved for Sony Mini-VTRs (https://www.dvinfo.net/forum/long-black-line/56035-synchro-edit-control-mystery-solved-sony-mini-vtrs.html)
Steve McDonald December 14th, 2005 06:30 AM
On the off chance that someone else in this NLE-centric group is using two Sony DV or Digital8 mini-VTRs, I'll pass on what I finally figured out about control communication between them. This might also be relevant if using a full-sized DV VTR with a mini model in the GV-D series.
I needed to edit and re-record a bunch of older Digital8 tapes onto DV. My Sony GV-D1000 is the DV deck and a GV-D200 is the Digital8 one. They are supposed to work together to do synchro-editing. However, after I'd edit-marked the segments on the Digital8 player and set up the DV deck to record, it just stayed in record/pause, while the player did its job. The FireWire passed the audio & video through just fine, but the control signal wouldn't start and stop the recorder. In case you're wondering, I had put the recorder through the recommended synchronization procedure with the player. Who would have thought that these close cousins wouldn't read each other's FireWire control commands? I didn't check to see if a FireWire command was properly passed, when the player and recorder's roles were reversed. I will look into that soon, but I'm not hopeful it will work any better.
So, as the manuals suggest, I set them up for IR control.
The DV deck still didn't respond. Luckily, I speculated that the IR command modes they send from their transmitters on the back, might be different than the mode #2 that is sent from the small remote controlers that Sony supplies with camcorders. They don't furnish these controlers with the mini-VTRs, but they recommend borrowing them from a camcorder, as they do operate the VTRs. The VTRs have to be set to mode #2 to respond to them. However, it turns out that the VTRs send out mode #3 commands from their own IR transmitters. So, the recorder in the editing pair has to be set to mode #3. After this adjustment, they work fine together for me, sending the A/V over FireWire, but needing IR for the edit control. The back of the player has to face the front of the recorder for IR communication.
Command modes and command codes: two different things. They must be set in separate parts of the Menu. But, I didn't find a hint about this IR command mode issue in the manuals. The command code for these VTRs is coincidentally, code #3, the default setting. The IR code setting should be checked in the Menus, to be sure both VTRs are on code #3.
Fortunately, I have a big, full-featured remote controler from an older Sony Hi-8 VCR. It can be shifted between command modes #1, #2 and #3, but the camcorder controlers are fixed in mode #2 only. The shuttle wheel and jog buttons on the big controler are very useful and if anyone has one from a full-sized Sony VCR, they work the little models from the DV-D series very well.
I also tried using my JVC HR-DVS3U DV/S-VHS VCR as a recorder with the GV-D200. The FireWire commands started and stopped its recording, but it skipped the first 3 seconds of each segment. There's no way to set the synchronization with the player on this deck, so it can be used only in completely manual, crash-editing. However, this JVC model works flawlessly over FireWire with my computer, responding precisely to its commands.
Many will be thinking that I should just use one mini-VTR and a computer, but these little gems can be easily taken into the field, to have a portable editing system, that runs on camcorder batteries. Most laptop computers that did a good job at NLE, would be bigger, heavier and more expensive. And there's the matter of saving wear on a camcorder during editing.
