Sony HVR M15 image problems
Hi all. Newbie here.
I have been using a Sony HVR M15 to capture from a Sony HDR FX7. The camera is set to output 1080i through iLink and the M15 is also set to receive this. I am recording at 50i on the deck and all the indicators show all is well. The problem is when I try to import into imovie the image quality is about equivalent to composite! Imovie is set to import at full quality and I am not having any issues with timecode or deck control. Does anyone have any ideas as to why the image quality is so poor? I ensured that the iLink cables were connected while the camera and deck were unpowered and did the same with Mac Pro that I am using. I am also using brand new Sony HDV tapes. I am just about at my wits end so any advice would be gratefully received. Thanks |
Re: Sony HVR M15 image problems
If you are judging the image quality by looking at the preview during import that's how it looks. But the actual imported video should be fine.
Thanks for that.
Sadly, it's the same poor quality when the imported video is viewed. Not just in the import preview window but in the event on playback. Still puzzled! |
A further update.
I have checked the output into a monitor and I am getting 1080i on the analogue component outputs. I have tried importing into Final Cut Pro and the same issue occurs with imported video. I can now only assume that there is an issue with the ilink output. I have tried a new ilink to firewire 800 cable and still the same. The strange thing is that both imovie and Final Cut control the deck fine. I think I am just going to use a Blackmagic Intensity and use the component outputs of deck and see how that imports. Still looking for any other ideas anyone may have though so please feel free to comment. |
Funny, I just happen to have used one of these decks at my old job, and I think I know the problem you're having. Check page 51 of the manual - I bet you've got the iLink downconversion turned on.
Under the In/Out Rec menu, go to iLink set, and then go to "Off" under Down Convert. Then, it'll spit out HDV over the Firewire port. If Down Convert is on, you're going to get SD DVCAM out of the port, which will, as you found, look pretty bad, at least in comparison to the original HDV. Hope that helps. |
Hi and thanks.
I checked the iLink setting and it is off. I list below the In/Out Rec settings HDV/DV SEL HDV REC MODE (Grayed out but when you scroll to it it shows DV SP) VIDEO OUT When executed shows COMPONENT 1080i/576i iLINK SET OFF COLOR BAR OFF BARS TYPE TYPE 1 DV BARS 16:9 EE/PB SEL EE 480i LEVEL. SMPTE Should I have anything else set differently? |
Why aren't you just popping the tape you shot on the FX7 into the deck and capturing from that? Why is the deck "receiving" anything? The deck should only be sending, not receiving. Just capture directly into your NLE straight from the original tape, using either the FX7 or the M15, making sure there is no downconversion in either playback unit, and make sure all the settings match in your NLE. I know this sounds patronizing and condescending, but your original post makes it sound as if you are making a completely unnecessary dub. |
No Adam, that's not correct.
I am using the ilink out of the FX7 into the M15 to capture live footage. I am not taping with the FX7 just using it as a HD camera. The only recording is taking place on the M15. The output of the FX7 is set to 1080i and the tape from the M15 has recorded HD footage as I can play it back through the component outputs and my Sony TV indicates that it is a 1080i input and the quality of the playback is great. It's only when I try to import the footage into either imovie or FCP that it appears rubbish! Thanks for your input tho. |
I don't have M15 but I have another Sony deck. At the I/O settings below, I import HDV footage to iMovie without any problems.
HDV/DV SEL --> AUTO DV REC MODE --> SP iLINK CONV --> OFF A/V -> DV OUT --> OFF You may want to check the actual imported MOV file in QuickTime inspector to see whether the format shows AIC 1920x1080 resolution. |
Thanks Pedanes,
I tried your suggestions but, sadly, it has made no difference. I already had the M15 set on HDV as I read on another forum that the auto setting can confuse the NLE you use. I'm going to try shooting HD on tape on the FX7 and importing that into imovie or FCP and see what happens there. If that's OK I'll try and import the same tape from the M15 and see what happens. |
What is the file extension of the file you imported via iMovie? If it is .MOV then check the resolution as I suggested earlier. If it is .dv then you need to find out why your M15 deck is outputting DV instead of HDV.
Why? |
The reason I'm taping on the M15 and not the FX7 is because I'm filming a research project and sessions are typically over three hours.
I can't enter the room where the research is taking place during the filming so I am unable to change tapes. |
It all makes sense to me now.
The most common reason for this type of thing is a settings mismatch in your NLE. Not saying that's what's happening here, only that it's the usual reason. Can you post a screen grab of all your settings in the Mac? |
| All times are GMT -6. The time now is 01:15 AM. |
