Pete Bauer |
May 28th, 2005 04:42 AM |
Hi Matt,
If you do switch tape brands, it is important to do a head cleaning in between. The general advice is that it doesn't much matter which brand of tape you use, but it is simplest to just stick with one.
Sony tapes are good, just formulated differently than Panasonics. So unless you have a particular reason to switch brands, such as sharing tapes with a colleague, there's no need to do so. But if you do switch, make sure to use a Sony head cleaner tape, or get the heads professionally cleaned, before putting in a different brand of tape.
