-   The Long Black Line (https://www.dvinfo.net/forum/long-black-line/)
-   -   an old vhs question (https://www.dvinfo.net/forum/long-black-line/43769-old-vhs-question.html)
Graham Jones April 29th, 2005 01:51 PM
an old vhs question
Just leafing through crappy cheap VHS recorders.. because today I have been fleetingly forced to use that horrible old medium!
If you want to feed a signal into a VHS recorder via SCART in order to record it onto a tape do you need a VHS machine with 2 X Scarts at the back - or is 1 X scart enough?
Rob Lohman April 30th, 2005 05:43 AM
1x SCART should be enough if it sees the input signal. And that's a difficult
one. Perhaps it's best to bring a dv camera with cable with a scart at one
end to test it out before buying? I'm not sure all VCR's (especially old ones)
support that...
If a VCR has 2x SCART it may be more likely to support it (why would you
otherwise need the second scart, in theory you could even do input & output
with just one).
