-   The Long Black Line (https://www.dvinfo.net/forum/long-black-line/)
-   -   pal/ntsc dv tape - is there a difference? (https://www.dvinfo.net/forum/long-black-line/42082-pal-ntsc-dv-tape-there-difference.html)
Jon Turner March 30th, 2005 01:49 PM
is there a distinction between tapes along pal/ntsc lines? are all tapes compatible with both formats?
Jim Sofranko March 30th, 2005 05:59 PM
Yes -DV tape records the data but the format (PAL, NTSC) is established in the camera. But once you record it one way it needs to be played back the same way with compatible components.
All DV tape is compatable with either format.
Chris Hurd March 31st, 2005 08:18 AM
Or to put it another way, *blank* tape is suitable for either PAL or NTSC, it doesn't matter. But once you record something to that tape, you can only play it back in that particular system.
K. Forman March 31st, 2005 08:21 AM
Or, the short version... No.
Jon Turner April 2nd, 2005 11:43 AM
thanks folks!
