-   The Long Black Line (https://www.dvinfo.net/forum/long-black-line/)
-   -   Three questions... (https://www.dvinfo.net/forum/long-black-line/26348-three-questions.html)
Dustin Waits May 21st, 2004 03:20 PM
Three questions...
First : How do you "black" your tape? What exactly do you do to the camcorder to black your tape?
Second : I was reusing a tape that had already been recorded on before and I noticed that there were some glitches in my footage. Is this because I was recording over something or could it be dirty heads?
Thrid : What brand head cleaning cassette should I buy? I'm using a Sony trv950 and I always use Sony tapes. And how often should I clean them?
Thanks.
Ken Tanaka May 21st, 2004 04:04 PM
First: "Blacking", or "striping", a tape is nothing more than recording blackness from end to end generally as a prophylactic measure against time code breaks. It's a waste of head and tape wear. With just a bit of thoughtfulness and diligence even a rank amateur can avoid time code breaks. Don't bother.
Second: Impossible to say. Any opinion would be empty speculation.
Third: Brand makes no difference whatsoever. They're all basically the same. Use them sparingly, which means when you start to see break-up in your images and/or when you change brands of tape (hopefully rarely). Just be sure you use the cleaning tape exactly as directed on the packaging.
Dustin Waits May 21st, 2004 04:20 PM
Thanks Ken.
