dupe a DV tape w/ FW and match timecode?
Hi. I need to backup some DV tapes. I am hoping to be able to use them for batch capturing when I res-up my project (FCP), so I'd like the timecode to match on the two tapes. Is there any way to do this with consumer equip? Either Sony DV cams or Panasonic AG-DV1000?
thanks, Aaron |
If you capture the clip and then export it to a blank tape you should
at least maintain the timecode. |
I copy from DSR 11 to DSR 11 all the time. I believe PD 150 and 250 can also do this. Just set TC to external on your record machine. We set all cameras & recorders to DF. Makes perfect 1 to 1 identical copies via Firewire. I backup all tapes we shoot this way. Your work is too valuable to risk.
Dave |
Consumer cameras don't have external TC controls. Pro decks and some prosumer camers do allow TC to be locked.
